EFI Product Development
Old Apr 6, 2005 | 05:45 PM
After Shark's Avatar
After Shark
Default EFI Product Development
You one get to vote once so make it count. If you have don't under stand the question send me a PM and I will try and clarify. Thanks for your time.
Old Apr 6, 2005 | 05:58 PM
duliz's Avatar
duliz
If I had the money to convert the fuel system in my car I would definitely get the PERFORMER RPM FI kit because you don't need a laptop to reprogram it, and the kit already includes a preprogrammed chip for your engine specifications. This kit also comes with very good intake.
Old Apr 6, 2005 | 06:25 PM
81 Vette's Avatar
81 Vette
St. Jude Donor '05
First C3 General Poster!
Im big on trying to bridge the gap between classic styling and performance heritage with modern technology, but I voted for a carbed up system with injection as well.
My C3 will have some technology integrated into it, and the engine, but all that technology is going to enhance the original SBC design and function as intended 33 years ago.
Old Apr 6, 2005 | 06:35 PM
DonBecker's Avatar
DonBecker
I have the controller for:
www.megasquirt.info
And have read up on the others. I like the fact that I have control over everything. With those 'brand-name' ones, there is no flexibility. Bah to that. The other plus is I can make it work with all kinds of different EFI setups.
Old Apr 6, 2005 | 07:20 PM
zwede's Avatar
zwede
www.megasquirt.info
Only one you have limited control over is the edelbrock system. The others (Holley C950, FAST, MOTEC etc) all give you total engine control down to the most detailed level.
Old Apr 6, 2005 | 07:23 PM
84rzv500r's Avatar
84rzv500r
That's easy...
RAMJET!!
Old Apr 6, 2005 | 07:41 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have always thought I would love to have the Holley Commander 950 in mine. I love the look of the setup, plus you can keep your original air cleaner and it maintains some similarity to stock look.
Old Apr 6, 2005 | 07:51 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i'm about $2000 away from doing this.....but someday.....
Old Apr 6, 2005 | 08:12 PM
mrvette's Avatar
mrvette
NOt that this has much if any bearing on today's situation, BUT, ten years ago it was rather difficult to do a DPFI setup that was not a stock controller, true that T-body systems existed, but an old OLDS racer friend with a '79 442 and a 455+++ turning like 11 seconds, but even he gave up and went back to carbs....shame really, would have bought that setup for the Goat, but it was just T-body, and so not what I wanted....
Not sure what I"d buy today, but cool looking is still a TPI setup, and what for electronics?? I am open to suggestions as mine is a stock setup with aftermarket chip I can't access easily....
GENE
Old Apr 6, 2005 | 09:38 PM
corvettecris's Avatar
corvettecris
I really am looking into TBI. It is a lot cheaper. and I think it would provide what I'm looking for: better mileage, more power, and improved cold starting and throttle response. YOu think?
Old Apr 6, 2005 | 09:47 PM
CorvetteDave01's Avatar
CorvetteDave01
Edelbrock now makes a new drag racing version of the proflo EFI setup. It's supposed to be good for up to 1500 hp for both sb and bb chevy. Injectors are some kind of variable rate set up, 60-80 lb/hr. rating I think. Don't know the price on it.
CorvetteDave01
It's also programable with a laptop, I forgot to put that in there.
Old Apr 6, 2005 | 10:59 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'm putting a modfied LT-1 manifold on top of my 4-bolt 412 SBC. I have the equipment and software to do my own eproms, and I'm ready to get to work. This is gonna be fun...
Old Apr 6, 2005 | 11:13 PM
mrvette's Avatar
mrvette
Batty, we need to talk, IM me, as I need change somethings on my prom, things that I dont agree with....
the timing pattern is one....
computer is a 1227730
GENE
Old Apr 7, 2005 | 10:47 AM
Z-man's Avatar
Z-man
I'll have to agree w/Zwede on this one. Most of the other brand-name systems are incredibly flexible. I've got the Holley C-950 and you are able to control every aspect of engine performance including idle, full throttle, acceleration, deceleration, throttle lift-off, narrow and wide band O2; 1,2, and 3 bar boost for super and turbo charged engines, fuel pump power, manifold pressure, throttle position, idle air control, water temperature, electric fan temperature control, transmission control, closed / open-loop control, and two other inputs for user-defined systems. The fuel injectors can be regulated in millisecond intervals from fully closed (0%) to fully open (100% duty cycle) over all ranges of operation, and these ranges are user-defined! The control combinations must be in the hundreds of millions. In addition to speed-density control, there is an alpha-n option (for drag racing, etc.). You can data-log all of this data either to the ECU or to a laptop. They are very flexible...
The poll needs an "other" category...
Old Apr 7, 2005 | 10:52 AM
flood's Avatar
flood
THe look of a TPI system is unbeatable. If there was a kit that fit under my 75 hood and was programable it would be nice. If rom chips are needed a rom burner and chips with the kit could come in handy.
Although I must admit Im a cheap-*** and if I ever go FI on the C3 I would go mega-squirt.
Old Apr 7, 2005 | 12:11 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
From the product discription, the new FAST XFI system sure sounds like it does it all. Including built in wideband O2 capability and sequential cylinder injection.
I own a MEFI (GM RamJet 502) and the Holley Commander 950 systems. MEFI is a good system if all you want to do is plug it in and go. It is very difficult and expensive to get any real diagnostic or reprogramable capability.
Like Zwede says, the Holley system is extemley flexable allowing full programability and relativly affordable. I love it, however, it is getting a little behind the technology curve. It still utilizes bank to bank injection and requires external electronics to support wideband O2.
I called FAST and they seem to be pretty proud of there technology.....retail ~$2500 for complete widband system including harness ( not a full system including intake and throttle body like the Holley Commander 950)
I think I will wait a little for the competition to get the price down before I upgrade the MEFI
Bullshark
To EFI Product Development
Old Apr 7, 2005 | 04:23 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
mrvette,
The big issue with reprogramming the '7730 and similar computers is the funky memcal unit. I'm going to get one and modify it for a replacable chip, but I'm also plenty afraid of destroying a good memcal. There are a lot of people out there who do programming for a fee, if you already know what you want it should help keep the cost down. For more info, check out the gm-ecm section of diy-efi.org. Anything I can help with, feel free to ask.
Old Apr 7, 2005 | 05:00 PM
LemansBlue68's Avatar
LemansBlue68
I always liked the 4X2 Weber setups with the mini-velocity stacks. An EFI version of that would be the catsass!
Old Apr 7, 2005 | 05:53 PM
75 Stingray!'s Avatar
75 Stingray!
I'd like to modify one of these for fuel injection
