DIY, dist. test machine
Old Apr 7, 2005 | 11:05 AM
comp's Avatar
comp
Default DIY, dist. test machine
anybody done??? been looking for but cost to much to buy Need more idea's , Thanks
Old Apr 7, 2005 | 11:49 AM
Matt Gruber's Avatar
Matt Gruber
while it is faster w/machine, we mostly do it in the engine w/timing light
Old Apr 7, 2005 | 11:51 AM
comp's Avatar
comp
yep but i'd love to go threw them and drop them in and time ,, my back
is about gone
Old Apr 7, 2005 | 12:15 PM
SpyderD's Avatar
SpyderD
You mean one of those sun machines that reconfigure timing and all that? I think they are obsolete, I doubt anyone makes them anymore.
Something like this? (already sold unfortunetly)
http://www.cornercarlot.com/sun_machine.htm
Old Apr 7, 2005 | 12:33 PM
Hvymtlc5's Avatar
Hvymtlc5
Wow - haven't seen one of those since shop class back in the mid 70's.
Old Apr 7, 2005 | 12:43 PM
comp's Avatar
comp
they still work just out of my budget
Old Apr 7, 2005 | 12:51 PM
lars's Avatar
lars
They're out there. I bought mine for $75 - Sun machine that's fully functional.
Old Apr 7, 2005 | 12:55 PM
comp's Avatar
comp
only one's i find are 4-500 buck's ....... i'd think getting the RPM's and deg's correct is going to be the hard part
Old Apr 8, 2005 | 09:19 AM
comp's Avatar
comp
nobody got in "idea's"
Old Apr 8, 2005 | 09:27 AM
Twin_Turbo's Avatar
Twin_Turbo
I'd love to land me one of those too, same as an old sun engine analyzer, sure is handy and looks good in the shop too. I know a guy who has one but he won't sell it although he's pretty clueless about the operation
Old Apr 8, 2005 | 09:28 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
They still use them daly at The Dyno Shop where is used to work.
Old Apr 8, 2005 | 08:21 PM
comp's Avatar
comp
yep make's things alot simpler
Old Apr 9, 2005 | 11:28 AM
w1ctc's Avatar
w1ctc
I've thought about this often. It would be fairly simple to do. 1. design a mounting to hold down the distributor. 2. get a motor with variable speed control (power drill?) to spin it at 2k rpm.(half engine speed) 3. Use an electronic tac like the ones used for model aircraft. 4. put a pointer on the rotor and a degree scale(don't forget to double the readings). You should be able to spin it up and watch the pointer advance with rpm.
Old Apr 13, 2005 | 12:16 PM
comp's Avatar
comp
and use a Mityvac to ajust the vac. advance ????
Old Apr 13, 2005 | 01:23 PM
stingr69's Avatar
stingr69
I have a crazy idea where I use a large camshaft degree wheel and a mighty vac to set the vacuum advance setup and the centrifugal advance amount, then just install and run the distributor with medium springs. Swap the springs up or down with the distributor back in the car so I get the curve to start a few hundred RPM above idle and thats it. Then just road test like usual. No fancy machine required.
Never actualy tried that but I see no reason it would not work. In the past I have just eyeballed brazing the slot closed a bit and filing it down to get the curve where I want it but that can method takes a lot more trial and error (time). Maybe next time....
-Mark.
Old Apr 13, 2005 | 01:31 PM
comp's Avatar
comp
sounds like it would work,,, are all the RPM measurement going to be half ?????
Old Apr 13, 2005 | 04:56 PM
Wrencher's Avatar
Wrencher
The old Sun machines are the way to go. They basically spin it up to any RPM you want and you can set points (remember?), adjust vacuum cans, set mechanical advance, all that good stuff. We had one here, but foolishly sold it for $25 bucks. What a mistake! Find an old timer shop in your area and they may still have one, or ask here and send our your distibutor to a fellow vette nut. I think Lars has one...
Hans
To DIY, dist. test machine
Old Apr 14, 2005 | 11:34 AM
comp's Avatar
comp
25 buck's i have 7 to do
Old Apr 14, 2005 | 12:43 PM
Matt Gruber
i can plot the weights' advance curve with a scale and calipers. just measure the tension to move the advance at various positions
Old Apr 14, 2005 | 12:48 PM
comp's Avatar
comp
How ??? never heard of doing it that way... you using a scale like a "trigger pull" scale
