how to remove knob from headlight switch?
Old Apr 11, 2005 | 09:17 PM
DaveL82's Avatar
DaveL82
Default how to remove **** from headlight switch?
OK this is crazy, I've changed the auto to a 5 speed, added rear coilovers but can't figure out how to remove the **** from the headlight switch.
I jumpered the switch a few years ago when the resistor for the dash lights went out. Now that I have the dash apart for the hydraulic clutch and hydra-boost conversion it seemed like a good time to replace the switch.
Dave
Old Apr 11, 2005 | 09:30 PM
StickShiftCorvette's Avatar
StickShiftCorvette
You need to get at the back side of the switch. If it is like a '69 you should be able to reach it by taking the upper side of the dash off. You should be able to see or feel a small headed pin with a coil spring below the head. Push that pin and the **** will pull out.
Old Apr 11, 2005 | 09:49 PM
lars's Avatar
lars
That's correct. You reach your hand up and grope around the switch behind the dash. On the one side of the switch you will feel a little spring-loaded pin or button. Push the button in and pull the headlight ****/rod assembly out of the switch. Note that this will leave your headlights in the "on" position, so you need to disconnect your battery.
Lars
Old Apr 12, 2005 | 06:38 AM
DaveL82's Avatar
DaveL82
Thanks guys it worked like a champ.
Now if I can only find the switch I bought 2 years ago.
Dave
To how to remove knob from headlight switch?
