Distributor alignment help
Old Apr 11, 2005 | 11:39 PM
69'Silver's Avatar
69'Silver
Default Distributor alignment help
I pulled the distributor from my 69 BB tonight, marked the rotor position, even took a dig pic. Went to replace it and now it won't go back in were it was. Did not turn the engine over or move it at all. It seems to want to go back in about 45 deg turned. What the heck did I do?
Old Apr 11, 2005 | 11:47 PM
PhotoVette1's Avatar
PhotoVette1
Place the distributor where you marked, measured, and swore it should go. Then, you can either reach in and align the oil pump shaft or, use the old school method and put a brick on top of the distributor and then jog the starter--it'll drop right into place. It worked for me.
Old Apr 12, 2005 | 12:23 AM
69'Silver's Avatar
69'Silver
Got it back in. Oil pump shaft..
To Distributor alignment help
