speedo problem?
Old Apr 15, 2005 | 12:33 AM
holley505's Avatar
holley505
Default speedo problem?
I have a 77 vette and My speedo is not working... these are mechanical so I thinking I just need to go with a cable first? any opinions? Does anybody have and idea of how easy or hard it is to intall and speedo cable..
the car has a TH350
Old Apr 15, 2005 | 02:48 AM
c3 in hawaii's Avatar
c3 in hawaii
the car has a TH350
If you can get the cable out from the trans, attach the end of the cable to a drill and rev it on low speed clockwise, watch the speedo, if it doesn't move, then it is your cable, if it does,then it may be the gearing in the trans. my speedo isn't working either, I did this and it works with the drill so I will be looking to change the speedo gear in the trans...
Old Apr 15, 2005 | 09:15 AM
gregk1's Avatar
gregk1
In my 77 the cable that goes from the cruse to the spedo was broke at the cruse unit they have trouble with the gears binding and messing up in the cruse unit so I have heard
Old Apr 15, 2005 | 09:32 AM
Ganey's Avatar
Ganey
Installing a cable is very easy.
Everyone is correct so far.
If you have cruise, you can expect the problem is the transducer breaking the lower cable.
If you want to bypass the transducer, a lower cable for 86-88 SS Monte Carlo should work.
Old Apr 15, 2005 | 08:46 PM
BKbroiler's Avatar
BKbroiler
Like Ganey said, changing the cable is easy, the hardest part is disconnecting and reconnecting at the back of the speedometer. I just changed the cable and sleeve and the speedometer itself in my 77 (no cruise control). The speedometer change is DIFFICULT. Good luck.
Old Apr 16, 2005 | 01:54 AM
holley505's Avatar
holley505
YES I have Cruise and it does not work either. I could by pass it for now until I get ready to fix the cruise the stalk is broken. ARGHH
So if I buy a monte carlo speedo i can just swap from tranny to the gauge and i should be in business?
Old Apr 16, 2005 | 08:16 AM
Ganey's Avatar
Ganey
You should be able to just swap the lower cable & connect directly to your upper cable.
Old Apr 16, 2005 | 09:47 AM
holley505's Avatar
holley505
where is the point of connection between the 2? I know the cable goes into the tranny, but where does the upper and lower meet? Under the car or behind the dash?
Old Apr 16, 2005 | 10:11 AM
Ganey's Avatar
Ganey
Under the driver side fender near the brake master cylinder.
To speedo problem?
