Demon vs. Holley
Old Apr 24, 2005 | 03:48 PM
TJ76's Avatar
TJ76
Default Demon vs. Holley
Replacement parts that is. Will Holley parts fit my new Speed Demon? I need to rejet, but don't know for sure if my Hollley parts are interchangeable. Not to mention, parts for Holley's are easier to come by in my locality. Thanks in advance.
TJ
Old Apr 24, 2005 | 05:51 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
TJ
i'm pretty sure the owners manual lists the parts that will interchange.
Old Apr 24, 2005 | 06:32 PM
lars's Avatar
lars
It all interchanges: Jets, power valves, gaskets, accel pumps, shooters. Mix and match.
Old Apr 24, 2005 | 09:48 PM
406shark's Avatar
406shark
Lars...
I believe that the jets will interchange as you say, but they are not rated the same...at least that is what I was told. I was told that you will have tuning problems if you go with Holley jet numbers compared to Demon jet numbers. Something about them flowing different? You could probably call Demon and get a comparison from them as to which numbers compare?
Just a heads up.
Good luck,
Jeff
Old Apr 24, 2005 | 10:00 PM
68/70Vette's Avatar
68/70Vette
What is the background info about Speed Demon. Is this a seperate company? Are they affiliated with Holley? If Speed Demon is a seperate independant company, what is there something about them that is special, what should I know about them????Thanks
Old Apr 24, 2005 | 10:13 PM
406shark's Avatar
406shark
Barry Grant is the company that makes the carbs.
They have the ROAD DEMON, SPEED DEMON, MIGHTY DEMON, & RACE DEMON ( I believe that is the extent of current line-up, but could be wrong).
Road Demon is for basic stock/very mild applications.
Speed Demon is for modified applications, comes in both vacuum & mechanical secondaries.
Mighty Demon is for hi-po applications with duration of at least 240 degrees at 0.050", with hi compression. Last I heard they added a model with vacuum secondaries to compliment the mechanical secondaries.
Race Demon is for...as the name implies...race applications.
Call or check BG's web site for which carb will work best on your application. Too many people guess which will work best, and then complain when they can't just bolt it on and have it work perfect. IMHO.
http://www.barrygrant.com/default.aspx
Good luck,
Jeff
Old Apr 24, 2005 | 10:31 PM
68/70Vette's Avatar
68/70Vette
Good luck,
Jeff
Thanks!!!!
Old Apr 24, 2005 | 10:46 PM
gkull's Avatar
gkull
Which Demon are you trying to tune. Lars has it down. I've got mine two pretty good. I changed back to my 750 SD because it's more dialed in with holes drilled in all four throttle plates
Old Apr 24, 2005 | 11:25 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
It looks like my 825 Race Demon has the holes in the throttle plates from the factory
King Demon is the one you forget, it is the equivalent of the Holley Dominator
Old Apr 24, 2005 | 11:31 PM
406shark's Avatar
406shark
:o
Thanks...that's why I usually put in a disclaimer such as "I believe".
I know I'll never be able to afford an engine that needs one of those, so I guess I blocked it out of my mind.
Jeff
Old Apr 25, 2005 | 06:33 AM
TJ76's Avatar
TJ76
Thanks guys. Looks like the Holley stuff won't go to waste.
TJ
To Demon vs. Holley
