vacuum system- allowable leakage?
Old Apr 26, 2005 | 12:38 PM
Turbo-Jet's Avatar
Turbo-Jet
Default vacuum system- allowable leakage?
if i connect my Mityvac to the headlight control lines, i can pull 20-25 inHg easy and it will hold for a while. if i connect to the heater control lines, it takes a several pumps to build up vacuum and once i get over 20 inHg, it gauge drops down to 10 in 4-5 seconds. is this leakage insignificant when you consider how small the line diameter is and how much air the engine moves?
Old Apr 26, 2005 | 02:31 PM
Z-man's Avatar
Z-man
If your hoses are in good shape, you should be able to put the headlights up for a day or two, or cycle them 4 - 5 times. It's probably just a matter of preference as long as the leaks aren't so bad that they affect the performance of your engine.
Old Apr 26, 2005 | 03:17 PM
lars's Avatar
lars
Turbo -
You are correct. That small of a leak will not have any noticable effect on engine operation.
To vacuum system- allowable leakage?
