Are headers worth it?
Old Apr 27, 2005 | 07:39 PM
stock77's Avatar
stock77
Cruising
Default Are headers worth it?
I have a set of Hedman headers from my uncle. Is it worth putting them on if I have to keep a cat. on it, or should I just leave the manifolds on? The whole exhaust needs to be replaced either way.
77 L-48
Old Apr 27, 2005 | 08:17 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
77 L-48
thisis what you need and its 3hrs from you and free.
http://forums.corvetteforum.com/show...4&forum_id=119
Old Apr 28, 2005 | 10:52 AM
steves_77vette's Avatar
steves_77vette
77 L-48
If the cat has never been changed its probably clogged solid. But, if you add headers and new cat you're probably looking at an easy 30-40 hp increase.
Old Apr 28, 2005 | 11:07 AM
fast idle's Avatar
fast idle
get the free set,then get the headers hooked up to a set of straight pipes with some cheap turbo mufflers(free flow).when it's time to re-certify, swap in the manifolds and smog stuff.
Do you have mobile set ups or do the police check??
we have nothing, and i like it just fine. the nearest sniffer is 250 miles away and comes around to offer free checkups once a year. no penalties, if you go in voluntarily they give you the printout,that's it.
Old Apr 28, 2005 | 12:10 PM
markdtn's Avatar
markdtn
For a bone stock or close engine, I doubt you will notice much improvement with headers. If you are making 350-400 hp or so it may help.
Old Apr 28, 2005 | 01:01 PM
Shark Racer's Avatar
Shark Racer
My bone stock Goodwrench 350 went from 0-60 in 7.1 seconds to 0-60 in 6.5 seconds with Hedman 1 5/8" headers. Like turning an L-48 into an L-82. Auto transmission.
I also noticed another 2/10ths of a second going from 2.25" true dual exhaust to 2.5" true dual exhaust on the same motor.
-Steve
Old Apr 28, 2005 | 05:42 PM
stock77's Avatar
stock77
Cruising
I don't have to get it inspected but I was told that if you run into the wrong state trooper he can have your car towed to a dealership to have it put back to spec. all at your expense. I also can't find any shop that will put the headers on for me without a cat. Some of the shops said I shouldn't waste my time with the headers and others were eager to do it, I think just for the money. I can do it myself without the headers but there will have to be some fabrication with them.
To Are headers worth it?
