I don't want a solid rear axle, I wouldn't have gone through all the trouble if I wanted that, in fact I'd have bought a camaro or something like that.
An S&W racecars 10 point but it'll be a 12 point when I'm finished with it, need to make the engine bay section myself because of the plumbing nightmare
Ah the whole drilling disease has caught on to Twin Turbo too!
I noticed the mysterious appearance of holes since the start of this post. There's never been any doubt that Twin Turbo and Norval are two of a kind. I think it looks kinda cool!
You may not want a solid axle, but when those u-joints let loose and rip like a chainsaw through your buttocks, you'll be wishin' you took ol' Dep's advice
Look where those halfshafts have to pass through to get into the passenger compartment, and I may run some halfshaft loops also. I've never had a u joint break, a diff yes (pinion area broke out of the case)
Got the shock mounts almost finished (one side only needs some gusseting and a strip of metal welded over the top of the mount to make it a u shaped channel, other side only has 1 side done)
why would you convert the rear IRS to a solid axle on a corvette other than one that is gonna be used for drag racing only? by the way nice work TT keep the pictures coming
Funny...the ORIGINAL Vette had a solid axle right up to 1962 and ran okay in BOTH styles of racing. IRS confined the Vette to roundy-round only. And even then, the solid rear axle Cobras blew past the Vette rather easily. So where's the advantage???
The advantage is in far superior camber & toe control (if designed properly). The cobras are much lighter, compare apples to apples. Again, I'm not interested in 1/4 mile (there's only 1 dragway here in the Netherlands and it's not even close to me)
Well it must be a theoretical advantage then
Cobras were competing in the same class as the Vette, so that excuse doesn't really wash. And get your hot rod on a boat and come on over here!!! One drag strip!!! Good grief!!! How do you exist over there????
That would be extremely hard to do and a lot of work, it's mean drilling 3 smaller holes for each triangular hole and then using a sabre saw to cut out the triangle. I'm going w/ round holes on the front "spreader bar" also (it's be a beam that is removable)
plus round holes are better than triangle sense triagle holes are more prone to stress cracks at the corners. i cant wait the see you rolling chassis TT it is looking awsome so far
