Headlights 81 corvette
Old May 31, 2005 | 05:26 PM
hankhenry's Avatar
hankhenry
Default Headlights 81 corvette
Anyone have this problem with their headlights.
I started the car and the headlights popped up all by themselves.
The only thing i did was start the car,the headlight switch was not touched. Now they will not close. Can anybody help me out.
HH
Old May 31, 2005 | 05:38 PM
Schwee's Avatar
Schwee
There's a small **** on the underside of the dashboard on the drivers side. Push it up to close; pull down to open.
Old May 31, 2005 | 05:50 PM
hankhenry's Avatar
hankhenry
Tried that but made no difference.
Also tried the light switch with no luck.
Well at least i can still drive it at night.
THANKS
HH
Old May 31, 2005 | 05:54 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
There should be three vacuum lines under the dash related to the headlights. One enters the firewall and goes to the headlight switch. One between the headlight switch and the switch under the column. And one from the switch under the column back through the firewall. Check to make sure they are all there and connected. One of them disconnected can cause the headlights to raise.
Old May 31, 2005 | 09:28 PM
hankhenry's Avatar
hankhenry
Found one disconnected and reconnected it and everything works as it should.
Thanks for the help.
HH
To Headlights 81 corvette
