Please help me identify what this does
Old Jun 3, 2005 | 12:21 PM
jazzpicks's Avatar
jazzpicks
Navigator
Default Please help me identify what this does
I bought an 82 last fall. when you open the hood there is a solonoid looking thing that looks as if it would open a door to let air in. There is a wire going to this. However the wire is disconnected and the door is tie wrapped shut. is this critical? What does it do? Where does the wire connect to on the car I can't seem to find a matching connector. I don't know if I should mess with it.
Old Jun 3, 2005 | 12:29 PM
TedH's Avatar
TedH
I'm assuming that is the ramair door that feeds the Crossfire injection. Correct?
Old Jun 3, 2005 | 01:02 PM
Twin_Turbo's Avatar
Twin_Turbo
Yea it's the hood air door, it should open on full throttle but people tend to rig it so it's open all the time. The system consists off the door, solenoid and control relay that's on the firewall next to the map sensor (next to the brake booster)
If it's not working after you connect the wire (which runs along the drivers side innner fender, there should be about 2 or 3 inches of wire on the solenoid and then a single black connector). I still have a good working solenoid, relay. door (foam is a little shabby) and bracket. If interested
Old Jun 3, 2005 | 01:05 PM
texaswilkins's Avatar
texaswilkins
Take it all off and wash the bottom area that is probably dirty. It will then allow cool ram air to reach the air cleaner the entire time you are moving and it will clean up the nasty bottom of your hood.
Bill
Old Jun 4, 2005 | 12:15 AM
JustinGJ's Avatar
JustinGJ
Shoot, this means my hood is not original, since my '76 has the flapper door with the wires leading to the front of the hood. Obviously they aren't hooked to anything. Too bad it wasn't vacuum operated like the cowl induction hoods on the SS Chevelles.
Old Jun 4, 2005 | 07:28 AM
Twin_Turbo's Avatar
Twin_Turbo
Does your hood also have the airbox that conencts to the CFI aircleaner? It has a sort of distorted oval shaped rubber seal.
Old Jun 4, 2005 | 10:23 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
Like our cars need another vacuum operated headache!
Old Jun 5, 2005 | 02:27 AM
kevinator80's Avatar
kevinator80
the truth spoken oh so clearly!
Old Jun 5, 2005 | 09:00 AM
an81shark's Avatar
an81shark
my goal is to get rid of vacuum operated stuff
Old Jun 5, 2005 | 08:44 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
I understand it's suppose to open only at certain speeds.
To Please help me identify what this does
