LT 1 heads?
Old Jun 5, 2005 | 04:19 PM
007-8's Avatar
007-8
Default LT 1 heads?
There is a set of LT1 heads online right now for $400.00. You can use any aftermarket intake and carb with those right? I am going to try to build a 400-425 crank hp motor (350) these would be a good buy and match for what I want right? All input is welcome.
Old Jun 5, 2005 | 04:22 PM
Corey_68's Avatar
Corey_68
What LT1 are you talking about 1970 or 1992+ corvette/F-body heads.
If it's the '70 version yes it will work, if it's the '90's version then it will not work unless you have an LT1 block. The 90's version has reverse cooling thus it will not work w/ earlier engines.
Old Jun 5, 2005 | 04:24 PM
007-8's Avatar
007-8
It's a 90's head. Thank you, you just saved me $400.00
Old Jun 5, 2005 | 05:28 PM
Corey_68's Avatar
Corey_68
No Problem
Old Jun 5, 2005 | 08:27 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
If you find a short block let me know, I have a set of 1993 Aluminum heads and a MFI w/ 63K on them for $350 plus the ride.jim
To LT 1 heads?
