Caliper Bolt Torque Spec
Old Jun 13, 2005 | 03:55 PM
captainmorgan's Avatar
captainmorgan
Default Caliper Bolt Torque Spec
I am upgrading my calipers with the VBP O-ring kit.
What do I torque the bolts to that bolt the caliper halves together?
Old Jun 13, 2005 | 04:52 PM
GTR1999's Avatar
GTR1999
I don't know about the O ring conversion but the halves should be 130 Ft/lb for the front and 60 ft/lb for the rear. Don't forget the O rings~!
Gary
NHvette's Avatar
NHvette
130 ft-lbs front
60 ft-lbs rear.
70 ft-lbs on the mounting bolts.
Old Jun 13, 2005 | 05:07 PM
mandm1200's Avatar
mandm1200
Originally Posted by NHvette
130 ft-lbs front
60 ft-lbs rear.
Right on the money!
Old Jun 14, 2005 | 12:30 PM
jwbert's Avatar
jwbert
Tighten just until they break, then back off 1/4 turn
Old Jul 5, 2022 | 10:49 PM
Rich123's Avatar
Rich123
Made my night. Search for torque specs and found this...
Old Jul 6, 2022 | 07:46 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Actually, the "Correct" Torque spec is....
Tighten till the bolt cracks, then back off 1/4 turn.
If the bolt breaks completely, you need to start over.
To Caliper Bolt Torque Spec
