HEI should fit without problems. The 8mm plug wires which the HEI will want will not fit the OEM 7mm plug wire grommets which were original to your car.
jacobs -
This is Lars writing from luerja's 'puter in San Francisco:
Any Chevy HEI will drop right in your Vette with no problem. There are 2 issues:
1. Chevy HEI distributors do not have tach drive provision
2. HEI requires that a full 12 volts be applied to the "BAT" terminal of the distributor. Your car is set up to provide dropped voltage through the restistor wire.
Thank you everyone. Lars, I have a 4MV Quadrajet that may need to be rebuilt. Are your rebuilding services available and if so what is the workflow? Thanks, Mike
I have an HEI in my 69. You won't have any physical fit issues. You can buy an HEI mini harness from the Corvette wiring suppliers like Lectric Limited or M&H electric. It will have factory ends and look like it belongs....only about 20 bucks if I remember right. I had my stock tach converted to late model electronic (the mechanism was out of a late Z28 if I remember right). This is not cheap, and requires recalibration of the retrofit tach mechanism. Otherwise you could always go with an aftermarket tach, or a 75-77 tach, although the guage faces are different.
Since I put on the HEI, I haven't had any problems. The car runs better than ever (although I made quite a few other changes as well). If I had to do it again, I would do it in a heartbeat. Good luck.
Run full +12v to distributor for HEI, no resistor. When I did mine I ran power from a switched +12V source so it was only energized when the key was on.
