Composite Spring ?
Old Jun 25, 2005 | 10:24 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Composite Spring ?
Can I put a 2 1/4" composite spring on a 2 1/2" mount. My 2 1/4" steel spring has winged spacers on the front/back and the composite spring does not allow that. Can I put something around the bolts to space the spring evenly?
Old Jun 25, 2005 | 10:30 AM
rihwoods's Avatar
rihwoods
Maybe that's why those things ....shatter....
Old Jun 25, 2005 | 11:48 AM
skydaddy's Avatar
skydaddy
Is the problem with the thickness of the spring? You could go to a hardware store and pick up some aluminum stock 1/8" thick and the same or a little thinner than the composite spring and then shape them to fit. I dont know if this is the problem but it may help.
Good luck. I will keep watching because I will be doing this soon as well and this was what I was thinking of doing.
Old Jun 25, 2005 | 11:53 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
I was steering toward alum. tubing and cutting it the same height as the spacer. That should center it. Thanks.
Old Jun 25, 2005 | 12:10 PM
fl_rider's Avatar
fl_rider
1/8" wall tubing shoud do the trick too.
Chris B
To Composite Spring ?
