Rod knock or header leak?
Old Jul 2, 2005 | 11:06 AM
Joebio's Avatar
Joebio
Default Rod knock or header leak?
Ok well my saga continues, got the new trans (3rd) in the car last night and fired it up. That is when I here a ticking noise that sounds like it is in the area beetween the top of the header and the oil pan near the collector. With it being late, dark, and being extremely discouraged I didn't want to deal with it.
When I start cold and trying to get it to idle it goes away during up and down of the rpm cycles, and if the car is stumbling at 500 rpm or so the tick is gone. When at any steady rpm I can hear it.
Someone please have good news for me that I probably just need new header and collector gaskets. I bought the motor used with 10k documented on the rebuild, and heard it ran in the other car before it was taken out.
Old Jul 2, 2005 | 11:11 AM
rihwoods's Avatar
rihwoods
Sometimes you can reach down and feel that leak.Don't burn yourself...
Old Jul 2, 2005 | 11:33 AM
page62's Avatar
page62
Most likely an exhaust leak. An engine with rod knock sounds awful at high rpm...
Old Jul 2, 2005 | 12:22 PM
johnt365's Avatar
johnt365
i had a nissan pu that started making a knocking noise. i lived with it for a long time and wrote it off as an older car noise. this was a KNOCK! like someone smacking the blick with a hammer, not a tick like like tapping it with a screwdriver.
this was my daily driver car. i was spending all my time and money on a project truck and neglecting my other cars maintenance needs
I FINALLY checked the oil on my little nissan. none on the stick. i freaked... filled her up with oil and the knock went away.
Old Jul 2, 2005 | 08:36 PM
Joebio's Avatar
Joebio
Update!!
Good news is that it is a header leak. Will pick up the gasket in the morning, good to go!!
Old Jul 2, 2005 | 08:52 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Good ... I figured. There's a huge difference between a rod knock and the tinny sound of an exhaust leak!
Old Jul 3, 2005 | 12:02 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
When your'e unsure of stuff like that, always eliminate the simplest things first! can save a lot of grief and stress in the long run!
Old Jul 3, 2005 | 01:15 PM
Phil Zell's Avatar
Phil Zell
Buy the dead aluminum gaskets, you can use them over and over and they will not burn out.
Old Jul 3, 2005 | 01:27 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I wound up getting some Stage 8 locking header bolts and some good gaskets. No leaks since they have been installed. I used to get a little leak about every 200 or so miles of cruising.
Old Jul 3, 2005 | 01:57 PM
Bullyj's Avatar
Bullyj
Eddie, did you get these locally? I just got the motor and trans back in. Me and Dad had to remove one of the headers and it didn't look like it was sealing good.
Old Jul 3, 2005 | 02:13 PM
Joebio's Avatar
Joebio
Just got in and witht the new gaskets no problem.
On a side note, can't someone design a header bolt that is not a PIA to put in?? I bout the ones that are allen heads inside, and regualar bolts outside, still took forevor.
Old Jul 3, 2005 | 06:42 PM
Eddie 70's Avatar
Eddie 70
Bill,
Got mine from Summit. You might be able to get them from Performance Products in Knoxville.
Old Jul 4, 2005 | 12:10 AM
yellow72's Avatar
yellow72
had the same thing happen on my C3 and it got way way way louder after a farily hard pull... i was about to die. went to the store bought a set and installed bolth on the driver side bank... started it up still a tick... remember to tightin the 2 bolts in the front... start er up... life is good!!!
Old Jul 4, 2005 | 09:46 PM
mandm1200's Avatar
mandm1200
If it's a rod knocking, it won't last too long. There are a lot more exhaust leaks that rod bearings, so the odds are in your favor. I think if you ever haerd a bearing go, you would know the difference. Bearing make a different noise, kind of a sick, $$, noise.
Old Jul 4, 2005 | 09:56 PM
Empatho's Avatar
Empatho
Old Jul 4, 2005 | 10:29 PM
jcswm's Avatar
jcswm
A loose spark plug can fool ya!!!
Trust me
Old Jul 5, 2005 | 09:50 AM
69396Chevy's Avatar
69396Chevy
Yes a loose plug can! Friend of mine was told by a garage he needed new lifters and rocker arms, 1800 dollars later when he got the truck back guess what . . . loose spark plug!!
To Rod knock or header leak?
