M20 or M21
Old Jul 11, 2005 | 06:42 PM
collectskulls's Avatar
collectskulls
Default M20 or M21
Just wondering what you peeps prefer the M20 wide ratio or the M21 close ratio.The reason i ask is i have the M20 in my car now but I have a rebuilt M21 that i have been carting around for 8 or 9 years and when i put my SB 400 in my car in the winter I am wondering which tranny i should use.
Btw my car has 3.36 reaR end
Old Jul 11, 2005 | 06:54 PM
stingr69's Avatar
stingr69
I generaly like the wide ratio for a torquey 400 engine.
I like the narrow ratio for high winding peaky small blocks that need to stay "on cam".
Not a lot of difference in the ratios either way. 2.20 vs 2.52 for the first gear is not a big difference.
-Mark.
Old Jul 11, 2005 | 08:51 PM
Gordonm's Avatar
Gordonm
M20 for the street. If you have 3.36 gears definitly go with a wide ratio
Old Jul 11, 2005 | 10:02 PM
pef427's Avatar
pef427
I personally like the short throw(faster shifts) of the M21.I seem to have an easier time keeping the weight transfered to the rear without dropping the nose under hard acceleration with the M21.
Old Jul 11, 2005 | 10:24 PM
Gordonm's Avatar
Gordonm
The M20 and M21 have the exact same throws. The only difference is the gearing inside the trans. You can make a M20 or 21 a short throw by using the lower holes in the shifter arms.
Old Jul 11, 2005 | 10:34 PM
pef427's Avatar
pef427
This is true. My buddy has his M20 set up with the long throw and I found that the longer throw seemed more truckish in the way it shifted. IMO. Again, it's personal preferences.
Old Jul 11, 2005 | 10:44 PM
Techno's Avatar
Techno
Since I'm I look at things differently.
You have one old tranny and one rebuilt. Put the rebuilt close ratio in.
Check me on this but the difference between the 2 trannies is the close ratio follows a ratio step while the other doesn't. 1st to 2nd is a step and so on. The other 1st to 2nd is a different step than from 2nd to 3rd and so on.
Old Jul 11, 2005 | 11:06 PM
A C's Avatar
A C
Cruise-In II Veteran
M20 for drag racing and street driving. It's a lot more street friendly, especially if you have a hot cam.
Old Jul 12, 2005 | 08:49 AM
ImBatman's Avatar
ImBatman
I had this same decision about 6 months ago. I decided to go with the wide ratio M-20 since this is mainly a street car and most of the power will be used in the lower rpm ranges. As far as the throw goes that depends on your shifter and the adjustment not the trannie. I am in the middle of rebuilding my M20 right now and learning a lot about how it works. In short if you don't plan on doing a lot of road racing autoX and you are doing most of your driving on the street I would stick with the M20.
Old Jul 13, 2005 | 12:04 AM
collectskulls
thanks guys
To M20 or M21
