MYSTERY Starter Wire
Old Jul 12, 2005 | 09:55 AM
Gforce454's Avatar
Gforce454
Default MYSTERY Starter Wire
I have a 1971 454 Stingray. There is a wire that attaches to the solenoid on the same terminal that the large cable from the battery attaches to, This wire appears to have two resistors or capacitors bundled inside of it.
1.What is this wire for?
2.Why are there resistors in this wire?
This wire is a bit ragged from 30+ years of being under the car. I would like to replace it, but the wire resistors and their purpose are a mystery to me.
Old Jul 12, 2005 | 10:11 AM
luerja's Avatar
luerja
I also have seen the resistor, so it is factory. Maybe it is there to prevent some kinda feedback noise to something. I am looking forward to hearing what it actually is. I'll do some checking in my library of books in the meantime.
Jim
Old Jul 12, 2005 | 10:34 AM
Gforce454's Avatar
Gforce454
Jim
Yes, it appears to be factory alright. My car has been in storage since the mid 1970s off and on. It even had the original brake pads when I got it back in 1988. Thanks for any help.
Old Jul 12, 2005 | 11:46 AM
Fevre's Avatar
Fevre
Believe that wire goes to the alt and those are fusesable links, look like nuckles or small barrels.
Old Jul 12, 2005 | 02:16 PM
Techno's Avatar
Techno
It may be a resistance wire for the coil. I think they used resistor wire but that might have been done instead.
Something about during cranking the starter is the resistance but while engine running there is no resistance so this was introduced.
Not all engines use it, a year thing.
My resistor wire is yuchy too and my brother installed a very high wattage resistor on the firewall. It gets hot.
I forgot the ohmage but can find out if this is your dilemma.
I should have described the resistance wire to eliminate that.
Its tan with a woven cover. Solid wire I think. You can't mistake it for any other wire since its the only one like it. Not plastic but woven insulation.
Old Jul 12, 2005 | 04:22 PM
Fevre's Avatar
Fevre
Believe those are connected to the cylinoid not the main post, the coil sees 12v during crank and then switches over to a wire with a resistor when running.
Old Jul 12, 2005 | 05:33 PM
lars's Avatar
lars
The wire that hooks up to the big solenoid terminal along with the positive battery cable is the wire coming from the alternator "+" terminal. It's this wire that charges the battery. The "resistors" are fusible links to protect the circuit in case of a dead short.
Lars
Old Jul 13, 2005 | 02:58 AM
Gforce454's Avatar
Gforce454
Lars
Lars, you are correct.
Can this wire be replaced? I looks ragged. The fusable links do appear to be intact but the wire insulation is hard and toasty looking.
Thanks to all for the help on my MYSTERY Starter Wire.
-George
To MYSTERY Starter Wire
