1981 header question
Old Jul 12, 2005 | 05:49 PM
dady24's Avatar
dady24
Default 1981 header question
On the pass. side there is some sort of vacuum thing on the side of the header itself. There is currently no hose conected. Anyone know what it is for and what it connects to and do I even need it.
Old Jul 12, 2005 | 06:10 PM
an81shark's Avatar
an81shark
uhh, you are talking manifold right? between the manifold and the exaust pipe?
its an emissions device to help the car heat up faster when its cold. vacuum is used to open it once the car warms up.
Old Jul 12, 2005 | 06:19 PM
Ganey's Avatar
Ganey
Probably EFE, Early Fuel Evaporation, heats intake manifold. Search on that.
Not needed in the south.
Old Jul 13, 2005 | 01:54 AM
stickboy's Avatar
stickboy
I don't remember where it connects, but I believe it was one of the 2 temp swiches that are in the water neck. If your emission sticker is still on your hood it will say on there. If you have an aftermarket intake or gaskets that blocks the crossover passage, don't connect the EFE
Old Jul 13, 2005 | 09:01 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
You'll also hear this refered to as a "Heat riser" sytems. As long as it's open, and without vacuum it should be, it should only affect performance when you first start it in cold weather. Not likely to be much of an issue for you.
To 1981 header question
