On my 81, everything in the system is new, I replaced the filter/orfice and recharged with R134. I have checked the heater core shutoff is working, and I have verifed the temp damper is in the A/C position. The A/C blows cool air, but not as cold as it should. The dryer is dripping water like it is cooling to beat the band! The compressor, like on my 77 trans am with R-134 is cycleing more that it seems like it should.. Any suggestions???
Need a little more info. Did you evacuate the system to 28Hg for 30 minutes and verify that it held vacuum for 12 hrs before recharging? What oil did you use and how much? How much 134a did you charge in and what pressures are you reading at what ambient temp when the compressor cycles?
I will get the readings, and I didn't evacute the system. My vacuum pump died last year. I put 2.5 cans in the system with the R-134 oil. Thanks for the pointers. I will post the reading tommorrow. Any more advice??? How much gas (r-134) should it hold? Am have no experience since R-12. Seems like R-12 would take about 3-3.5 cans.Thanks a million!
There you go. Your trying to compress air and water. It's essential to pull vacuum for a good long time in order to boil out the water vapor that an open system collects in very short order.
