How Does the Column come apart?
Old Jul 16, 2005 | 05:41 PM
evalu8r's Avatar
evalu8r
Default How Does the Column come apart?
I bought new bearings for my 79 steering column but can't seem to figure out how get it apart at the pivet point of the tilt. I found 2 screws that really loosens everything but still doesn't come apart. Helllppp!!!!
Chris
Old Jul 16, 2005 | 09:22 PM
Jim Shea's Avatar
Jim Shea
The following paper and the three pages that follow should help.
http://www.corvettefaq.com/c3/T&TColumnD&R306AP05.doc
http://www.corvettefaq.com/c3/T&TDis...age122MY05.doc
http://www.corvettefaq.com/c3/T&TDisasmPage2.doc
http://www.corvettefaq.com/c3/T&TDisasmInstrPage3.doc
Jim Shea
Old Jul 16, 2005 | 10:59 PM
evalu8r's Avatar
evalu8r
Thank you very much. That is an awsome paper.
Chris
Old Jul 17, 2005 | 04:41 PM
an81shark's Avatar
an81shark
sounds like you need to take the two pivot plugs out of the side of the tilt portion
Old Jul 18, 2005 | 08:48 AM
Vette Gator's Avatar
Vette Gator
I just found a trick that might be useful when you reassemble your column. Getting the C-clamp in place that holds the locking plate can be a real bear. I pushed the plate in as far as it needed to go, then inserted the ends of two paint can openers into the slot at the 3 and 9 o'clock positions. These held the plate in place, which allowed me to maneuver the C-clamp in without having to maintain tension on the spring. These are the tools they give you at a paint store that look like screwdrivers, but with a 90 degree bend at the end. Jim Shea also mentioned a bridge tool, but since I didn't have one of these handy, I had to improvise.
Old Jul 18, 2005 | 09:09 AM
jaycjackson21's Avatar
jaycjackson21
Gator - did you use a steering wheel puller (I think that's what it's calleD)? I've read that this tool is also required.
Thanks,
JCJ
Old Jul 18, 2005 | 10:17 AM
Vette Gator
Yes, I did use a steering wheel puller. A friend suggested that I could just yank on the wheel hard enough and it would come off, but I did't feel comfortable putting that much stress on the column, so I bought a puller (around $20 at Sears).
To How Does the Column come apart?
