VBP Performance Plus Spring rates?
Old Jul 18, 2005 | 08:23 PM
1970-Bronze's Avatar
1970-Bronze
Default VBP Performance Plus Spring rates?
For those who are running the VBP Performance Plus system, what spring rates do you have? BB or SB?
If you don't know, it's written on the springs as a 4 digit code I believe.
Old Jul 18, 2005 | 11:15 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Not sure but I think the number is an in-process spring test that relates to spring rate. VBP could tell you what spring rates are best for BB/SB.
Old Jul 19, 2005 | 08:55 AM
1970-Bronze
I sent VBP an e-mail and a PM and I haven't heard back.
I found a guy with a kit that was never installed and I wanted to check the spring rates.
Old Jul 19, 2005 | 10:19 AM
BBShark's Avatar
BBShark
I asked this question to VBP and got this reply:
Originally Posted by BBShark
Alan,
I puchased the VBP front mono spring and rear dual mount spring (42600 and 42030). The springs are both hand marked. One has 7717-1, TVL and K:600. The rear has 7735-5, RDM and K:238. What do these marks mean?
BBShark,
The 7717-1 and 7735-5 numbers are our in house production numbers. The first 4 digits is the spring slab run, the last number (1-5) is what position on the slab your spring was cut from. The 600 and 238 numbers are the spring rates (Lbs./in.) when bolted on our fatigue and safety test machine. These numbers are lighter than the actual spring rates at the individual wheels as the tester does not hold the spring at the same points as the front and rear transverse system brackets do.
To VBP Performance Plus Spring rates?
