Door Hinge
Old Jul 18, 2005 | 11:05 PM
BBtrimmer's Avatar
BBtrimmer
4th Gear
Default Door Hinge
I am restoring a 71, it appears that when you open the passenger door all the way the leading edge of the door panel hits the lower hinge. The door opens and closes without any problems. Is this a hinge problems or a door panel adjustment?
Old Jul 19, 2005 | 11:00 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The hinge spring should stop the door before it nicks the edge.
Old Jul 19, 2005 | 11:23 AM
ksbunting's Avatar
ksbunting
Easy Mike is correct. I had the same problem on my 68 and it nicked the door. My spring was missing and I didn't notice it until after the damage to the door. Replaced the spring and now it doesn't hit anymore.
Old Jul 19, 2005 | 01:59 PM
Edzred72's Avatar
Edzred72
Sometimes the door spring will pop out of it's lower pocket too.
Eddie
Old Jul 19, 2005 | 11:37 PM
Retro78's Avatar
Retro78
I had this problem. There is a stop built into the hinge also, my body man built it up a little with some weld on the stop to make sure it will not happen again even of the spring pops out.
Old Jul 19, 2005 | 11:39 PM
big_G's Avatar
big_G
Replace Both hinges...they are sprung. You can red-neck them and weld in some stops..lol
Old Jul 20, 2005 | 08:51 PM
ckerch's Avatar
ckerch
I have the same problem. Which hinge has the stop in it . The upper or lower?
Old Jul 20, 2005 | 09:31 PM
big_G's Avatar
big_G
I believe BOTH have stops
To Door Hinge
