Turn Signal Help
Old Jul 19, 2005 | 08:20 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Turn Signal Help
Okay I bought new flasher relays new turn signal switch checked all the wires, and I still do not have any turn signals. I have hazard lights all except the driver side front, this is for the hazards I have no turn signals but hazards except for the driver front. any help would be appriciated thanks.
Old Jul 19, 2005 | 08:39 PM
Silver00V6Camaro
car is a 75 thanks
Old Jul 19, 2005 | 08:48 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Did you check all the wires to ground?
big_G's Avatar
big_G
There are 2 flashers..Hazard is on the fuse box, and I think the turn signal flasher for the 75 is just behind the map pocket, by the courtesy lamp.
Old Jul 19, 2005 | 08:53 PM
Silver00V6Camaro
All of the wire are new and all of the grounds are good. I already replaced the flasher for both the hazard and turnsignals and still have nothing but the hazard with no driver side front hazard or turnsignals of any.
Old Jul 20, 2005 | 12:58 PM
Silver00V6Camaro
Okay found my problem it was the lt blue wire that comes from the firewall to the turn signal. The wire pulled out of the firewall so I just re soldered it back in to there and bam I have working turnsignals. Thanks for the replys.
Old Jul 20, 2005 | 02:12 PM
jaycjackson21's Avatar
jaycjackson21
Do the flasher units work independently of each other (I think the answer is yes) or do they both need to be functioning for turn signals to work?
Thanks,
JCJ
Old Jul 22, 2005 | 08:44 AM
jaycjackson21
ttt
Old Jul 22, 2005 | 08:49 AM
big_G's Avatar
big_G
Jay, yes they are independent.
To Turn Signal Help
