Rear Bearing?
http://www.corvetteforum.net/c3/zwed...railingarm.htm
What's wrong with your shift key?
All joking aside, you might want to jack the car up and give the back wheel a feel. Check to see if there is any wiggle in it up/down/side/ etc. There should be none. Roll it around and see if the sound is there when the load is off.
You could have a bad bearing, parking brake, brake pad, e-brake cable could have snapped and is on the inside of the rim. You could have a bad U-joint. They will make a sound once the grease dries up and the bearings start to fail. You will really have to isolate one thing at a time until you locate the noise.
The wheel bearing is a pain in the butt. I rebuilt my own, but I would encourage others that don't have the tools, resources, or time to simply ship off to Van steel or VB&P for new ones.
Also, if you conclude it is a wheel bearing, consider doing both trailing arms together as the other is sure to go soon too.
Good luck!
Good luck!
with all that ... plus I would add that it could also be aworn differential side yoke. As they wear down, the dust shield starts to rub the casing.
Probably the parking brake or even the caliper brake and hopefully it is.
