semi-metalic pads?
Even someone who does spirited driving will find organics inadequate. Yes the organics will stop the car great once, twice maybe 3 times from speed but when you play on the curves multiply that by 50.
Its simple, do you want to save a 35 dollar rotor or do you want good brakes?
The performance friction carbon metallics are very easy on rotors but create that nasty black dust that will cost you points at the show and shine event.
I drive spirited most of the time. Run about 120 miles Wednesday night with alot of it at 100 mph taking curves at up to 3 times the posted speed. Run organic pads too. Never noticed any brake fade.
No $35 dollar rotors here. Bare they were $700 plus tons of machining.
My wifes car and my truck have metal and neither stops as well as the vet. Wish they made organic for them
You don't get the fade because you drill your rotors to let the pads outgas. Most guys just aren't going to go to the trouble to do that and i don't think you are going to get the same performance had you not drilled.
I also don't come up to stop signs and hit the brakes really hard. Sure I am moving and usually take the stop at a 2nd gear roll but agian I am trying for smoothness.
While turning the rotors in the lathe I found the 32 curved vanes really pumped the air. The air comming off them was like a strong fan. They really do pump air from the center out.
As for maintaining the car I seem to go over it almost weekly to try and spot a problem and that includes a visual brake rotor inspection.
I do not show 'n shine my car. I drive it, but I don't autocross it and there are no mountains around here that require enhanced braking components.
I know it's difficult for you, but you should really try to be polite for once instead of being a troll. Which you often are.
this right after you called a good post Nonsense?
we're just a bunch of opionated ole farts disscussing a subject in a spirited way. I'm sorry i hurt your feelings but it is often necessary to be dramatic to drive a point across.
You just managed to push my "hot button" -- the show 'n shine thing. I just reamed out some poor soul over in C5 gen because he was extolling the virtues of clear floormat protectors.
I drive my car. Hard. It gets wet and dirty, too. After all, it's a car...not a museum piece!
I've just got to put in my 2 cents (well, actually a lot of sense
).We recommend organic for the basic daily street driver - not for any type of performance or heavy duty uses. A good organic pad handles heat just fine under 'normal' street driving conditions and is very clean (low dust). They also do not eat up the rotors nearly as fast as a semi-metallic pad will. They sell for $15.95 (part # 11401, $14.35 with the CorvetteForum discount). Also, we will match any advertised price (see further up this thread).
The semi-metallic pads will absolutely stop better than organic pads. They will also handle higher temperatures before brake fade becomes a problem. They are a good and very economical pad for low and medium speed autocross events, hard mountain driving (sounds fun), etc. The down side is that they can be noisy, create a lot of dust and will decrease the rotor life allot faster than an organic pad will. These sell for $19.95 (part # 11402, $17.95 with the CorvetteForum discount).
Today, with newer technologies, (and higher prices - go figure) you can have better stopping with very low dust, low noise, and a higher temperature tolerance. Carbon-Metallic Pads from Performance Friction or Ferro-Carbon Pads from Hawk Brake are what we recommend for most anyone wanting better brake performance. Both brands have several compounds of friction material for use in street driving all the way up to NASCAR and other race only apps.
I personally recommend either brand of carbon pads and then just pick the compound needed for each application. (i.e. Hawk HPS for street, HP Plus for aggressive street / weekend warrior apps and Blue-9012 pads for high performance autocross apps. There are also Hawk compounds, HT-10, HT-12 and HT-14, for specific racing applications. Performance Friction also has VERY good pad compounds; Z-Rated, Silent Ceramic and Carbon Metallic. Prices on these types of pads range anywhere from $35 to $100+ for C3 applications.
The differences between the pad types are very noticeable. The organics are quiet and clean but are not for performance use, the semi-metallic pads are a performance pad but generate dust and can be noisy and hard on the rotors. The carbon compound pads are the best of both worlds. They are quiet, low dust, easy on the rotors and have greater heat tolerance. Different compounds are available for just about any type of application.
We sell (imagine that!) all the pads I have spoken about and the manufacturers both maintain great web sites loaded with information. For slightly more $$$, just about ANY carbon compound pad is going to be much, much better than organic or semi-metallic.
Hope this info helps someone…
Sincerely,
Alan G.
Vette Brakes & Products, Inc.
http://www.VbandP.com
800-237-9991
... and exaggerate, too. The absolute cheapest you'll find a decent rotor for is $50.
$35 won't buy anything I'd even put on my CRX.
$50 - That's what I pay locally for a Raybestos stock replacement.
Most good to best rotors are close to (or over) the the $100 mark.
I guess that's the price you pay, if you want to play on the track or mountains.
-Dave - the tightwad
I do mostly mountain driving in our area...never have had a brake fade running hard on organics...I think those that have issues have not paid attention to rotor "run out" at installation of new pads...
I hang out here just to watch the fights!
