I just changed out my organic pads for semi metalic and was surprised that it seems to take more pedal pressure but also seems to stop better. Is that pretty normal?
Yes, once the pads seat, it will be better. The trade off for harder effort is that they will stop better under hard useage, and less chance of the rotors glazing.
The only time to use anything other than organics is if you're autocrossing (or similar usage).
I'd rather have the slight extra pedal pressure of organics than have to remove and turn (or replace) my rotors in a few years. Organics are cheap and effective. They stop my car extremely well.
I used them autocrossing in the eighties...after two seasons,they hot spotted my rotors..had to replace them..also learned from experience that stock pads were actually adequate,even on the longer courses...
I like the organics too. I ran semi-metallic for a while, but the noise drove me nuts. It was embarrassing. I always drive with the top down, too, which only makes it worse. I've found the performance of the organics adequate for street driving (I've never had the car on a track).
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Originally Posted by Jughead
I had SM's but switched back to organic. Too much dust and noisy.
, cept I went with ceramic, not on the vette - pads are still good - but on my wife's car. That noise almost drove me nuts with her complaining about it
I tried performance friction metal pads but noticed the rotors were being destroyed so I went back to Wagner organic pads. I also found my metalic pads worked better once they got some heat into them.
Brake pads are "good enough" until you run into something because you couldn't stop in time. New rotors every few years probably costs less than full coverage insurance. (Especially if you're 21.)
Nonsense. The organics stop the car as well (if not better than) the semi-metallics I had before. And living where I do, panic stops are a daily occurrence. VBP recommends organics for street driving -- would they do that if they considered them "inferior"?
The fancy brake pads are only needed in situations of repeated braking (i.e., autocrossing), where heat becomes a serious issue.
I can always tell who the show and shine guys are. They are the ones using organic pads. Being from Texas i guess you have never done any mountain driving in the vette. (Quite the shame because its a ton of fun, but very hard on the car and tires.) The organics will go away quickly and you will have NO brakes.
Even someone who does spirited driving will find organics inadequate. Yes the organics will stop the car great once, twice maybe 3 times from speed but when you play on the curves multiply that by 50.
Its simple, do you want to save a 35 dollar rotor or do you want good brakes?
The performance friction carbon metallics are very easy on rotors but create that nasty black dust that will cost you points at the show and shine event.
