Brake Idiot light
Old Aug 10, 2005 | 11:55 AM
neilb33's Avatar
neilb33
are the wires attached to the master cylinder?
MELVINJ's Avatar
MELVINJ
Ill bet its the parking light switch. Since its hardly used, grease and grime really puts the wack on it. Remove the parking brake housing cover (be sure you remove ALL the screws before removing it. Be aware, early C3s have a screw that attaches the back of the console, and is accessable from the center compartment in the back)
You will see the swicth right inder the brake handle
