Brake Idiot light
Old Jul 25, 2005 | 03:39 PM
lil ski's Avatar
lil ski
Default Brake Idiot light
My brake Idiot light comes on sometimes for a few seconds sometimes it stays on for a while. My question is what makes it come on? My brakes work fine, fluid is full. I'm not sure where to look.
Old Jul 25, 2005 | 03:56 PM
big_G's Avatar
big_G
The parking brake and the brake system failure switch both connect to the brake lamp. 1 of these circuits is on intermittantly. The brake system switch is on the proportioning valve.
Old Jul 25, 2005 | 06:08 PM
Duke94's Avatar
Duke94
I agree if the brakes feel good, gotta be the e-brake switch. Only other possibility I can think of is if the wire to the switch on the proportioning valve is somehow shorted.
Next time it comes on, pull the wire off the proportioning switch, if it doesn't go out then it's the e-brake switch.
Old Jul 25, 2005 | 06:39 PM
Techno's Avatar
Techno
Easier, next time it comes on push the brake handle down more.
Old Jul 26, 2005 | 06:23 AM
lil ski's Avatar
lil ski
The E Brake has never been used so its probably the proportioning vavle wire I will try that when I get home. The light stayed on all night last night and the brakes felt no different than usal. As always thanks for the help!
Old Jul 26, 2005 | 07:57 AM
GaryS's Avatar
GaryS
What year car?
Actually, I don't think that the switch on early sharks is anything more than a warning light for low pressure. I don't believe that proportioning valves were used early on. If you can eliminate the parking brake, then you have a bad master cylinder. You will get a flash from the brake light when the MC lets go for a moment or two. I had this situaion on my 72.
Gary
Old Jul 26, 2005 | 09:18 AM
Techno's Avatar
Techno
Easiest to hardest.
Cheapest to most expensive.
The parking brake switch is in there with the handle. Don't matter if you ever used it and more likely to be the problem if you haven't.
Think about it, like a door light switch you never use that door but the lights are on. Is the door actually closed? Is the switch adjusted for the closed door?
Or is it the headlight switch? Same concept.
Old Jul 26, 2005 | 09:37 AM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Had the same prob. it was the Ebrake switch.
Old Jul 26, 2005 | 09:56 AM
big_G's Avatar
big_G
Originally Posted by GaryS
What year car?
Gary
The proportioning valves were first used in '67 vettes. The switch IS a bias-failure device. It lets you know that one of your brake systems (front or rear) has a problem......
Old Jul 26, 2005 | 11:29 AM
GaryS's Avatar
GaryS
I agree that it lets you know one of your brake systems has a leak. I still question whether it is a true proportioning valve.
Gary
Old Aug 10, 2005 | 06:38 AM
lil ski's Avatar
lil ski
I removed the wire from the proportioning valve and the light went off. But that didnt solve the problem. The light would not stay on all the time but the brakes did seem to be working fine. I took the car out on a back road ran it up to about 55mph and spiked the brakes hard. The light went out and has not come back on since maybe the proportioning valve was sticking a little and that freeded it up. What ever it did it worked so far. Thanks for all the help.
Old Aug 10, 2005 | 08:12 AM
pws69's Avatar
pws69
Incorrect. It just monitors pressure differential between front and rear and if one leaks, the piston will go to that side and turn on the light.
Proportioning valves didn't arrive until the 70's - I believe somewhere around 75.
Old Aug 10, 2005 | 09:49 AM
big_G's Avatar
big_G
Well, I'll call them that, due to the restrictor in the block for the rear brakes....I have had all year "Proportioning" valves apart, up to the '82's. I never saw any type of "Valve"...lol, just a piston with o-rings...looks like a spool valve....
Old Aug 10, 2005 | 10:00 AM
neilb33's Avatar
neilb33
Default i have the same problem
parking brake light stays on but the parking brake is down. what should i do?
Old Aug 10, 2005 | 10:12 AM
big_G's Avatar
big_G
Did you disconnect the "Proprtioning valve" switch connector? If so, then pull the parking brake housing, disconnet the p/b switch and see if the light goes off. If the brake light goes off when you disconnect the p/b switch, repair or replace it.
Old Aug 10, 2005 | 10:20 AM
neilb33's Avatar
neilb33
Default stupid questions
Where is the porpotioning valve connection on the car? I really need help with this sorry
Old Aug 10, 2005 | 10:27 AM
big_G's Avatar
big_G
Early C-3's they are mounted on the master cylinder with a bracket, the others are mounted either just below the alternator, on the frame, or on the frame at the bend just below the drivers door front edge...G/L
To Brake Idiot light
Old Aug 10, 2005 | 11:23 AM
lil ski's Avatar
lil ski
In my 74 its mounted on the frame just in front of the drivers door
Old Aug 10, 2005 | 11:31 AM
neilb33's Avatar
neilb33
what about a 1980? That box next to the alternator to the left?
Old Aug 10, 2005 | 11:41 AM
NHvette's Avatar
NHvette
Follow the two brake lines from the master cylinder ... they lead to the
proportioning valve or distribution block - whatever you want to call it.
I bet it's on the frame rail - down near the drivers floorboard, but follow
the lines - they will go right to it.
