outer tie rod removal
Old Aug 4, 2005 | 09:40 PM
fcoppola's Avatar
fcoppola
Default outer tie rod removal
Ok this is nutz. I removed the cotter pin and nut. I took my tie rod end pickle fork and hammered it in, like it says. I have completely shredded the rubber bushing doing this. the tie rod end is loose (meaning it rotates). How do I get this off?
I am installing steeroids, and the it says to seperate the tie rod ends from the steering knuckle. Does this mean completely seperated? Is the bolt that I removed the cotter pin and bolt from a part of the tie rod end? It appears so from my chiltons book.
I just dont see how to get this off. Both sides are at the same point. No matter how many times I pound on them they dont come off. Can I just pound down on the nut sticking up (where I removed the cotter pin and bolt)?
Old Aug 4, 2005 | 10:22 PM
rcread's Avatar
rcread
Tricky buggers, aren't they? I've always been fond of the tie rod puller. I've had way better luck with that than a splitter.
Old Aug 5, 2005 | 10:54 AM
norvalwilhelm's Avatar
norvalwilhelm
This is a little confusing. If you removed the nut and used a pickle fork and you say it is loose it will just fall out the bottom of the steering arm.
Since you have already destroyed the boot why not just buy 2 new tie rod ends. The outer tie rods are left hand thread.
While I only use a pickle fork on joints that are not going to be reused I too like a puller and save the boots on anything that is being reused.
There a different size pickle forks too.
Old Aug 5, 2005 | 11:04 AM
mandm1200's Avatar
mandm1200
What size hammer are you using? A carpenters hammer will not really do it. Do yourself a favor and pick up a tie rod puller. Harbor Freight has them for about $7. I used a pickle fork to break loose the steering knuckle from the ball joints on one side. Then used the puller, after getting one, on the other side. Day and night difference. One side took 20 minutes of beating and the other took less than 2 minutes.
Old Aug 5, 2005 | 03:36 PM
fcoppola's Avatar
fcoppola
Oh I'm not re-using these. I am installing steeroids, and will be replacing these. I am going to get a tie rod puller today on the way home. I thought all I was going to need was the pickle fork. Oh well its only $10 wasted. I doubt they will take it back considering the disformation from all the beating it took.
All I did so far was take the cotter pin off, removed the bolt, and then in an attempt to knock it off wedge the pickle fork in there. Yes I am using a mini carpenter hammer, not even a full size one. I was cursing the hammer last night. I will pick up a more manly hammer along with the tie rod puller, just to be safe!
Old Aug 5, 2005 | 03:42 PM
big_G's Avatar
big_G
My favorite hammer for tie rods is what I call a "Lump Hammer". About a 4 lb. slege, with a 8 in. handle. I call it a lump hammer 'cuz if you drop it on your foot, you WILL have a lump.....
Old Aug 5, 2005 | 03:46 PM
NHvette's Avatar
NHvette
The pickle fork will work. The threads coming up are a tapered
pin. You need a few whacks with a 3-4 pound hammer and the
tie rod will pop right out. If not, try a little heat on the knuckle
around the pin. The tie-rod puller is nice, and sometimes a
2-jaw gear puller can be used to push the pin out.
I also use a "Lump Hammer". They might be described as a "drilling
hammer" at the store. Another thing you don't want to do is miss
with the hammer and "Lump" your finger up.
Oh yeah - and always use the hammer in your "good hand" for better aim.
Old Aug 5, 2005 | 07:57 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Here's what it looks like once it's out - isn't it ugly ?
and this is how you get the tie rod end off the steering rod:
and here's the new tie rod end installed:
hope this helps, btw, they sell a tie rod end puller for $10 and a adjustable "multi use" puller for $29 - both AZ - I'd get the adjustable one since you may be able to use it on other 'projects'
Old Aug 5, 2005 | 11:24 PM
fcoppola's Avatar
fcoppola
Default wahoo
ok a few minutes on each side with the tie rod remover and POP they're off.
Lets see remove two bolts attaching the steering column to the rag joint. Ok lets see whats a rag joint?
Old Aug 7, 2005 | 07:34 PM
fcoppola's Avatar
fcoppola
Default Wahooooo
I FINALLY go the entire steering system out!!! What a feeling! Especially doing it with NO power or air tools!! Not to mention frozen 30 year old bolts!!!
Thanks yall!!!!
BEER FOR EVERYONE!!! (as long as they pay for their own!)
To outer tie rod removal
