Tall deck Big Block
Old Aug 5, 2005 | 12:59 AM
74droptop's Avatar
74droptop
Default Tall deck Big Block
Will a tall deck fit? Will it clear the brake booster and a/c box?
It's time to step up the power level so I'm gonna go BIG BLOCK
Thanks,
Old Aug 5, 2005 | 09:34 AM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Yes it will fit. That's what I have in my 68 with BB hood. Standard valve covers clear the booster and standard exhaust manifolds clear the A/C box (just barely).
Old Aug 5, 2005 | 09:42 AM
mayberg's Avatar
mayberg
So would a 572 fit? I would think you'd have to remove the booster. I'd probably want to go to hydroboost anyway.
Old Aug 5, 2005 | 10:46 AM
norvalwilhelm's Avatar
norvalwilhelm
I needed to run a stud girdle and tall valve covers so there was no way a vacuum booster was going to fit. I went hydroboost and anything will clear now.
The taller block needs a special intake, longer distributor and pushes the headers further outboard and possible steering box to header clearance.
Most avoid the tall deck blocks.
Old Aug 5, 2005 | 11:39 AM
Vesa's Avatar
Vesa
What is hydroboost?
Old Aug 5, 2005 | 11:53 AM
norvalwilhelm
Originally Posted by Vesa
What is hydroboost?
Hydro boost is a hydraulic braking assist that replaces the vacuum unit. The hyroboost runs off the power steering pump. It is an extremely powerful compact unit that comes with diesel trucks and vans. It it cheap at the autowreckers and most of the unites through the 80's and 90's are the same and almost a bolt it fit for our vets.
I provides clearance for tall valve covers and improves braking power.
Old Aug 5, 2005 | 12:01 PM
Vesa's Avatar
Vesa
Very interesting Any pictures of your setup after hydroboost installed?
Old Aug 5, 2005 | 12:34 PM
84rzv500r's Avatar
84rzv500r
Std BBC 9.800" deck height and tall deck BBC is 10.200" deck height only 400 thou or less than half an inch.
I considered a 572 with spacers to mount a Ramjet intake but went with the 502.
but a 572R with a 250 shot of nitrous would be WAY cool and be great for scarin ricers and midnight metallurgy experiments
Better yet a 572 with 5-6 lbs of boost from a 6-71 blower....
Dreaming.....
Old Aug 5, 2005 | 12:54 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Better yet a 632!!
There's one on the Forum going together right now in a '72. It will be a stick shift crosscountry driver with A/C!!!
Cool......guess his weenie little 540 just didn't scare him enough!
JIM
Old Aug 6, 2005 | 01:22 PM
hubes's Avatar
hubes
try doing a search for tall deck, there are a few threads in the archives
p.s. i must have missed this project with the 632, could you post a link? thanks
Old Aug 6, 2005 | 01:28 PM
collectskulls's Avatar
collectskulls
http://forums.corvetteforum.com/show...949&forum_id=3
Old Aug 6, 2005 | 08:27 PM
74droptop's Avatar
74droptop
I'm cosidering building a 540bb,but will 600 plus hp be too much for this car??
I already have traction problems now what about breakage of the rear and half shafts??
Old Aug 6, 2005 | 08:39 PM
601P's Avatar
601P
Check out this web site
http://diabolicalperformance.com/c3bigblock.html
Pulled the following from the site..
Do NOT try to use a tall-deck big-block engine. The 0.4” offset screws up your exhaust, brackets, intake manifold, etc. Just don’t do it.
To Tall deck Big Block
