Checking frame alignment
Old Aug 6, 2005 | 04:11 PM
Patience's Avatar
Patience
Default Checking frame alignment
Before I spend bucketloads of money on new suspension, steering, roll cage etc, I'd like to do some basic measurements to make sure my frame is pretty close to square. Any suggestions on what measurements and what landmarks to use.
My manuals say to pick identical landmarks on the frame rails and measure an X pattern. Anything within 3/16" is supposed to be okay. Any thoughts? I know I could take it to a frame shop, but I wanted to do some checking on my own first.
Old Aug 6, 2005 | 04:15 PM
big_G's Avatar
big_G
The easiest part of the Corvette frame to get damaged is the front frame extensions, just ahead of the front cross-member. (The front sway bar brackets bolt up to it.) Look for tears and/or wrinkles in the frame at that point. Other than that, use the cross-check and heights at similar points, if you have a lever floor.
Old Aug 7, 2005 | 05:45 AM
Patience's Avatar
Patience
I'm curious about the height checks at similar points. That won't work if I've got uneven suspension sag, right?
Old Aug 8, 2005 | 10:13 PM
dboz's Avatar
dboz
I bought these. I think it is the best way to check all aspects of your frame.
http://cgi.ebay.com/ebaymotors/1970-...QQcmdZViewItem
Old Aug 9, 2005 | 11:39 AM
71redskin's Avatar
71redskin
Default checking frame
hey dboz, any way you can fax or email that sheet to me. i'm concerned about my frame also...pm me or email to glfahlcron@msn.com
Old Aug 9, 2005 | 10:42 PM
dboz's Avatar
dboz
I should have it around here someplace. Used it over a year ago. It will take some looking but i will see what i can do.
To Checking frame alignment
