Crazy stall out issue..
Old Aug 8, 2005 | 10:27 AM
DonBecker's Avatar
DonBecker
Default Crazy stall out issue..
I have a stock 76 L-48 4 speed.
When I drive around town it's ok, until I get on the highway. Once I get to fourth (about 30 secs after I change gears) it will start to stall out. If I hold the gas pedal down, it will start to buck.
I've changed the fuel filter, fuel pump, fuel pump hoses, HEI coil, cap, rotor and last night I rebuilt the carb and it still does it.
It has a new 160o thermostat in it, and will do this on the highway, hot or cold.
After it dies it takes about 3 minutes to be able to restart it.
I bought a timing light the other day, where do I hook it up to check the timing?
Could this be a timing issue?
I dropped and resealed the gas tank last year so I don't think that's it.
Old Aug 8, 2005 | 02:13 PM
DonBecker's Avatar
DonBecker
Anybody?
Old Aug 8, 2005 | 02:40 PM
76custompaint's Avatar
76custompaint
What are your rear gears and what rpm are you at when it starts to stall?
Old Aug 8, 2005 | 03:25 PM
67L36Driver's Avatar
67L36Driver
"I dropped and resealed the gas tank last year so I don't think that's it."
With what? That stuff you slosh around inside? Maybe some of it is floating around in there and restricting the fuel pickup.
What shape is the rubber hose that makes the tank/hard line connection? Kinked?
Old Aug 8, 2005 | 04:39 PM
Star79's Avatar
Star79
could be a million things.
one of the million: Maybe the gas tank is not getting vented properly (is the canister and return lines all still there and connected?) Undo your gas cap some (so that it isn't airtight) and drive it around.
Old Aug 8, 2005 | 04:48 PM
DonBecker's Avatar
DonBecker
I cleaned the tank out, removed the rubber bladder and sealed it with the POR gas tank sealer.
The hoses were kinked, but I replaced them with SS braided while I wait for the molded to get here. They don't appear to be kinked now.
I replaced the gas cap 2 days ago with a new vented one, so I dont' think that's contributing.
Old Aug 8, 2005 | 04:51 PM
CGGorman's Avatar
CGGorman
Check your timing, vac advance, and power valve.
Old Aug 8, 2005 | 04:57 PM
lars's Avatar
lars
Timing won't cause the issue you're having. Sounds like fuel starvation. "Tee" a fuel gauge into the fuel line right at the carb inlet. Run a long fuel line to a fuel pressure gauge and run the line out of the engine compartment and tape the fuel pressure gauge right to the outside of your windshield to you can see it while you drive. Then, take the car out and drive it until the problem occurs. Watch your fuel pressure. If you drop below 4 psi, you have a problem with fuel delivery.
Old Aug 8, 2005 | 05:20 PM
Phil Zell's Avatar
Phil Zell
On some Q-jets there is a very tiny screen in the bottom of the seat, for the needle and seat. If your carb has one it is probably partially plugged.
Old Aug 8, 2005 | 06:35 PM
DonBecker's Avatar
DonBecker
Power valve (power piston?) is fine in carb.
If the fuel pump requires the engine running to have pressure, and the engine stops running, how do you figure out that the loss in pressure is not from the engine running?
Not trying to be a smart @ss, just trying to make sense of it.
Old Aug 8, 2005 | 07:48 PM
marshrat99's Avatar
marshrat99
I'm with every one that it sounds like a fuel problem. On the long shot that you're getting way too much advance, here's how to check your timing:
1) Connect the + lead of the timing light to the + post of the alternator
2) Connect the - lead of the timing light to a good ground such as the alternator bracket
3) Connect the sparg plug clip to your #1 spark plug wire. This will be the wire going to the plug located closed to the radiator on the drivers side. Do not disconnect the plug wire from the plug !
4) Start the engine and let it warm up to normal operating temps.
5) Stop the engine. Disconnect the vacuum line going to the vacuum advance at the distributor. Plug this line.
6) Loose the distributor hold down bolt until the distributor can be turned with little force but not too loose.
7) Restart the engine.
8) Adjust the idle to about 700-800 rpm.
9) Observe the position of the timing mark on the balancer relative to the timing pointer on the timing chain cover.
10) Slightly rotate the distributor until the timing mark aligns at the 10-12* before top dead center. IE, advanced by 10-12*.
11) Stop the engine
12) Tighten down the distributor
13) Reconnect the vacuum line
14) Restart the engine and reset idle to 700-800 rpm.
15) Have a couple brewskies !
Old Aug 9, 2005 | 12:36 AM
DonBecker's Avatar
DonBecker
marshrat99, thank you a ton for the step by step!!
May sound simple to some/most, but not having been there before it can be confusing the first time around.
BTW, I changed the ignition module tonight and had the same problem.
I read Lar's paper on finding the TDC. When I swapped plugs, I took all the old out and grabbed a 14mm bolt and thought I'd try seeing if my balancer was off.
I went to turn the engine over with my big rachet and I ended up tightening the center bolt abit.
This kinda scared me off of trying to turn the engine over (I'm a smaller guy).
Does it take alot of force to turn it over? I'm afraid of adjusting the timing and having it worse than before due to the balancer having slipped.
Also, if it came down to it and I got a new balancer, getting a fluid one is worth the money right? To prevent slippage?
Thanks again to everybody chipping in to help. I haven't found it yet, but all the suggestions have got me several steps closer!
Old Aug 9, 2005 | 12:58 AM
BigBlockk's Avatar
BigBlockk
I think I would look at the fuel line sock in the tank.
BigBlockk
Later.....
Old Aug 9, 2005 | 09:28 AM
67L36Driver
Try some low air pressure from a compressor at the fuel pump end of your hard line and listen at your gas cap opening.
Slipped harmonic dampers are relatively rare but I had one slip on a '57 Desoto hemi (Anyone remember them?) in my '53 Ford truck. The main reason I changed it out for a 318" Plymouth.
Old Aug 10, 2005 | 12:56 AM
DonBecker's Avatar
DonBecker
Well, checked the timing, it was 8o so I think I'm ok there.
I replaced the vacuum brake thing on the carb (as it was wasted) and it seemed to have no effect.
Crazy question, I've heard of old OEM cams wiping lobes before, could it somehow be that the fuel pump lobe was damaged sometime in the past?
Can someone fill me in on this fuel pressure gauge? I have a hardline going to the carb, do I just cut it and use some fuel line and a T fitting? Do you guys just tape the gauge on the back of the hood or something?
Old Aug 15, 2005 | 11:49 AM
DonBecker's Avatar
DonBecker
Okay, tank was dropped on Saturday.
Turns out the supply line was pinched. It was not underneath the tank strap, so the only suspect I have at this point is the sheet metal surround that goes around the gas tank.
So I was talking to my father about it and I suggested running hard lines. He advised no on that one, as the vibration might cause a leak.
Anyways, I went ahead and bought a new line. Then I went down to Home Depot and bought 2 rubber sanding blocks.
I used one and cut the top off of it, then taped it to the tank, right beside the hoses. I also taped the hoses down to the tank. Now, here's an interesting bit, the supply line (3/8") is towards the front of the car, and the return line (1/4") is towards the rear.
Why does that matter? Well, the pass. side frame rail has the fuel lines on it. The supply line is towards the rear of the car, while the return line is towards the front. Presents a great opportunity to have the lines cross at some point and may put the squeeze on (only my supply line was pinched so I don't think the return had anything to do with my problem).
Another word of advice, hook the return and supply lines up to the tank/sender, put it in, and then hook them up to the hard lines.
When I tightened the tank down and looked down at the filler portion, I could see the surround, it had moved closer to the gas cap (the overflow hides it). Anyways, see that made me really think that the surround had something to do with it and confirmed that the rubber block was preventing the surround from pinching the rubber lines.
Let me know if you have any questions on all this. Sorry, I forgot to take pictures of the whole thing as I was really starting to loose patience with it.
BTW, the spec. for pump flow rate is 1 liter (approx. 2 cups) per 30 seconds of cranking. Keep in mind that you will most likely have to jump your car after testing 3 or 4 times.
To Crazy stall out issue..
