Backup light switch mounting
Old Aug 10, 2005 | 10:24 PM
wellsw's Avatar
wellsw
Default Backup light switch mounting
I have a 74 with a 4 speed. When I bought the car it had no backup light switch on the transmission. I have now accumulated the parts to install a new switch but I am not sure exactly where the mounting plate for the switch attaches to the tranny. If anyone has a similar setup or has done this repair before I really need some help here. Thanks, Wells
Old Aug 10, 2005 | 10:48 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
the bracket bolts to the lower 2, rear, inspection cover bolts. then the rod attaches to the reverse lever. i am getting a new one myself and mine is not on the trans, otherwise i would take a pic and post it. hope this helps.
Old Aug 11, 2005 | 08:40 AM
Boofers's Avatar
Boofers
Not sure if you have the same tranny as me but here are some pics of mine, maybe they can help you out.
the switch mounted on the tranny
the bracket without the switch.......................the switch removed & opened up
Old Aug 11, 2005 | 08:56 PM
wellsw's Avatar
wellsw
Default I think I got it!!
Thanks, Guys. I see the two bolts I need to attach the plate to. It is the last lower bollt and the rear one farther back but slightly higher. I wasn't sure if it was those two or the two one the very bottom at the same level. Thanks, again and here we go. Wells
To Backup light switch mounting
