wiper door
Old Aug 15, 2005 | 09:19 PM
vette70's Avatar
vette70
Default wiper door
how do you get the wiper door open if engine off or vacaum doesn't work.
Old Aug 15, 2005 | 09:36 PM
cosmicvette's Avatar
cosmicvette
I have had to manually override my wiper door (as the vacuum or the overide switch doesn't work ).
Inside the engine bay (on passenger side) - up against firewall - is the wiper door actuator.
Take the rubber grommet off the front of it.
Then with something that wont scratch the inside (we used the handle of a screwdriver) - push the actuator in until the door fully opens.
Mine is a 1970.
Old Aug 16, 2005 | 11:37 AM
rponfick's Avatar
rponfick
You can also grab the rear edge of the wiper door and gently force it open. That's what I have been doing on my '69 as I try to get the linkage adjusted properly. P robably easier if you remove the vacuum hoses from the can first to not be fighting cylinder pressures.
Old Aug 16, 2005 | 12:22 PM
CGGorman's Avatar
CGGorman
Do it the way it says in the owner's manual! You know...those booklets that nobody ever bothered to read when they were new and then threw away just before selling the car to the second owner who never even knew the thing existed?
Anyway...
1. Disconnect the lines going to the canister.
2. Pull the big rubber plug out of the front end of the cannister.
3. Using a blunt instrument such as your finger or a socket extension, push the actuator in (toward the rear of the car).
4. The door should now be open.
Old Aug 16, 2005 | 12:43 PM
markdtn's Avatar
markdtn
Anyway...
When all else fails, read the instructions
Old Aug 16, 2005 | 12:59 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
You don't need to disconnect the vacuum lines, just be gentle when you put your finger in there.
Old Aug 16, 2005 | 03:51 PM
highschool67's Avatar
highschool67
I beg to differ.
If you don't remove the vacuum lines from the canister at least the closing side vacuum line, you may be trying to fight the vacuum on the "closing side" of the canister vacuum.
It opens like a dream if you remove the lines.
My .02
To wiper door
