78 battery cable
Old Aug 16, 2005 | 01:38 PM
geoc's Avatar
geoc
Default 78 battery cable
The positive side battery cable. Unless I keep it just as tight as I can get it there isn't enough contact to start the car. I've checked the connections and there isn't any corrosion on the contacts. Do they make anything you can maybe put on the contacts where I wouldn't have to tighten it all the time?
Old Aug 16, 2005 | 03:02 PM
Scottys78's Avatar
Scottys78
This sounds like a strange problem. You can get a bottle of electrical contact cleaner at your local hardware store, but I don’t think that is it. Are your terminals on the top or side of your battery? Maybe its grounding out or shorting out.
Old Aug 16, 2005 | 08:29 PM
toyvet1's Avatar
toyvet1
Neices Beretta had similar problem, just needed a washer between the battery and the cable. Sounds bubba but it worked.
To 78 battery cable
