Wheel stud ?
Old Aug 22, 2005 | 04:56 PM
FB#1's Avatar
FB#1
Default Wheel stud ?
Has anyone replaced their wheel studs with longer ones ? I'm going to need them for the wheels and spacers I am going to use.
Any tips on the rear wheels in particular, can they be replaced without removing the axles ?
Old Aug 22, 2005 | 05:52 PM
Techno's Avatar
Techno
I don't have the answer to that but you might be interested in adapters rather than spacers.
How thick of a spacer are you using?
Old Aug 22, 2005 | 06:00 PM
big_G's Avatar
big_G
You now have a 716 stud...if you need longer go to 1/2 in. stud...IMO..Longer studs will be hard to replace without removing the axles....
Old Aug 23, 2005 | 12:00 AM
CrossedFlags77's Avatar
CrossedFlags77
I replaced all my studs with longer ones a month ago. These are the studs I used.
ARP Wheel Studs...
The fronts are really straight forward to change. The rears require you to drill a hole in your dust shield in order to get the longer studs in.
Old Aug 23, 2005 | 02:12 AM
Twin_Turbo's Avatar
Twin_Turbo
I have 3" long 1/2" studs from moroso. You need to redrill the hubs for oversize holes as the knurl is a good deal bigger.
To Wheel stud ?
