I am new to the forum hope someone can help with this. I just put a new brake system (M-cylinder, lines & calipers) on my C3. I manually bled the system, pressure bled from the calipers, dropped the front end to level the master cylinder (to get any air out). No pedal! Any ideas?
Bench bleed the MC. Otherwise, it will take forever to get them bled. A pressure bleeder will also help. Not sure what you meant by "manually bled system, pressure bled from calipers".
Did not bench bleed master cylinder. It took forever to pump fluid via the pedal but I did finally get good air-less flow at each bleed point. Because I did not have pedal at that point, I pressure bled the system from each wheel back to get air out of the master cylinder (if there was any). No indications of any air in system. How do I tell if the master cylinder is the correct size (bore, whatever)?
You are going to have to remove it and bench bleed. It took me 40 minutes on the bench pumping while tapping before I got all of the small bubbles out. I cannot imagine how long it would take on the car...days?
I am really going to show my newbie/greenness here-How does one bench bleed the master cylinder?
instructions typically come with the unit. But basically clamp in a vise with short tubes from each outlet looped back into the MC. Then pump and tap...and pump...and tap....different stroke lengths etc until absolutely no air bubbles are left inside the MC.
I didn't think bench bleeding would be necessary after having gotten the thing to pump and then pressure bleeding from the calipers back. I did tip it back and forward during the process. Did I mention that I am using Dot 5 fluid?
I do not know about the 'pressure bleeding from the calipers back'...I have only seen pressure bleending at the MC or vacume at the calipers(which does not work well IMO). Many people have gotton good results pressure bleeding at the MC. The vette MC's are a real problem to get all the small micro bubbles out...they get trapped below. Before you take it out for bench bleeding you might want to have someone pump the pedal while looking down into the MC to see if you can spot any bubbles down in entry holes. It takes very little in these C3 brake systems to cause a lot of frustration.
You don't have to remove the master to bench bleed it. You can do it on the car. Get some short pipes and route them back into the master opening. Then pump the pedal until no air is present. Like this.(I know this is not what your master looks like, but you get the idea.)
Why bother trying todo this in the car and having to jack up the rear end. After installing the bench bleed tubes there is only two nuts left to have it sitting on the bench.
True it is only 2 nuts, but it is much easier to push the pedal than it is to push in the plunger with a scredriver. I did not jack up the rear for either the stock or the new master and had no air in the system.
1978SA: Yep, its all mine... unless you want to buy it for the right price.
Thanks for the info/advice everyone. I bit the bullet and pulled the master last night. 45 min. - 1 hour later I have all the air out. Now to get it back in without introducing too much back in.
The 68 MC has what looks like bleeder nipples in the main MC body. If never seen these in any other MC. Anyone knows if these are intended to be used to bleed the MC?
My MC is in the car, it's dry, and I just don't want to remove it. Rather than bench bleed it, I was planning on just jacking the car up so the MC was parallel to the ground. Maybe the 68 MC with what looks like bleeder nipples will make this job easier.
My MC was "restored/rebuilt" by Paragon. It's has stainless steel inserts. I have all new ss brake lines and new SSBC calipers. The system is all new and dry. I'm planning to use DOT 5.
When I received my restored MC back for Paragon, I was disturbed that what looked like an unpainted cast iron body had some small rust spots. I decided to clean the MC body with lacquer thinner and brush off the rust. The lacquer thinner removed the "rust!" It turns out the MC body was not unpainted cast iron - the body was painted to look like natural unpainted cast iron, and the "rust" was paint also!!! The Paragon restoration service made the MC look like it did on a new car; i.e. unpainted cast iron with a little rusting. This is pretty obviously something done to appeal to NCRS folks.
I just went through approximately the same dilema. I ended up removing the MC to bench bleed it. It just didn't work doing it on the car, even level and slightly nose down. What worked well on the bench was about 20 degrees nose down.
