DEMONS With IDLEZE...Please Read
Old Aug 24, 2005 | 12:24 PM
nastee383's Avatar
nastee383
Default DEMONS With IDLEZE...Please Read
If you have a DEMON with IDLEZE, how many turns counter clockwise did it take for you to fine tune your idle?
Old Aug 24, 2005 | 01:21 PM
lars's Avatar
lars
Close it completely and set up your idle speed by balancing the primary and secondary throttle blades at .020" transition slot exposure. Then balance your idle mixtures and re-set idle speed by adjustig pri and sec idle speeds equally. No need to use the Idle EZ - it has little to no effect, and merely creates an un-needed vacuum leak.
Old Aug 24, 2005 | 04:04 PM
Boofers's Avatar
Boofers
Sounds like they should have named it IDLELEAKY.
Old Aug 24, 2005 | 06:59 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Will this work with all carbs or just this one I have a holley 4160 model it is a 600 cfm. Sorry about the tread hijack figured It might help not only me but maybe someone else. Thanks
Old Aug 24, 2005 | 07:55 PM
nastee383's Avatar
nastee383
I set the throttle blades at .020 and the car won't start. It'll only run when I open the throttle blade using the curb idle screw. Then it idles too high, 1600 rpm. If I slowly close the throttle blades it dies @ 1400 rpm and belches out white smoke from the carb. The mixture screws are worthless with the throttle blades open. I've tried disconnecting the vac adv., different float levels, idleze closed, idleze open from 1.5 turns up to 5 turns, fuel pressure from 4 psi to 7 psi, mixture screws from 1 turn out to 2.5 turns out, less timing, more timing. It'll only fire if I have the throttle wide open as I crank it. I don't know what else to do. I've gone through a starter and 5 gallons of gas over 2 weeks trying to get this thing to idle properly. I'm going
Old Aug 24, 2005 | 08:57 PM
73C34me's Avatar
73C34me
Not a lot of info as far as motor specs, but... I would offer that you need to reduce the size of your idle feed restrictor. This will lean out your idle speed amount of fuel. I believe it will effect all range of rpm, but most noticable on idle. I have a mighty demon on my 383 & needed to do this. before idle rpm was 1250 & choppy. Post modification it will idle at 900 rpm & die at 500. This was waaay more effective than changing the low speed air bleeds.
Old Aug 24, 2005 | 10:32 PM
ylose's Avatar
ylose
Hope you get to your issue.
I have used three Demon carbs without issues. 2 ZZ4 Demon carbs and now a Mighty 650BT (Blow-through)
Use the LARS demon guide.
Old Aug 25, 2005 | 11:08 AM
lars's Avatar
lars
You have problems far more significant than the adjustment of the IdleEZ.... If you have to hold the throttle wide open to start, and cannot obtain idle below 1400 rpm, you either have engine problems not related to the carb, or you have a carb that is grossly flooding out the engine due to some defect, or a massive vacuum leak, such as an open PCV vacuum port. Check, verify and set timing at 36 degree total to rule out ignition problems, and then troubleshoot your issues - you don't have an adjustment issue - you have a significant technical problem. You may want to swap out carb with another carb to assist in your troubleshooting. If you want, you can send me your BG carb and I can check it, set it up, and verify it for you.
Lars
Old Aug 25, 2005 | 12:30 PM
OldSchool's Avatar
OldSchool
Anybody have a link to this?
Old Aug 25, 2005 | 03:01 PM
lars's Avatar
lars
Right now, my home computer is down, and I can't respond to e-mails or send out anything. But if you drop me an e-mail request for the paper, I'll send you a clean current copy of the procedure as soon as I get back up on-line again:
V8FastCars@msn.com
Old Aug 25, 2005 | 03:03 PM
OldSchool's Avatar
OldSchool
V8FastCars@msn.com
Thanks Lars..Email sent
Steve
Old Aug 27, 2005 | 06:08 AM
nastee383's Avatar
nastee383
This is my first DEMON. It seems simple enough. I ordered it Dec 04 and just got around to installing it recently. Once I started looking at it closely it appears it may have been tampered with and then returned. Some of the hex screws are mangled. It is a Speed DEMON and BG says all Speed DEMONS come with a progressive secondary link but this carb has a one to one link on it. If that is the case I'm stuck because the warranty has expired and the 90 day return period is long gone.
Old Aug 27, 2005 | 06:22 AM
nastee383's Avatar
nastee383
Lars
I'm almost certain it's not engine related. When the motor is running it sounds good with no missing/stumbling etc. It's pulling 16 in. of vacuum when it's running at 1600prm. (242/248 @ .050 HR cam) It responds instantly to throttle input, doesn't overheat or anything. I do believe it's flooding or getting too much fuel somehow. I don't have a full exhaust on it yet, only about 2' of pipe out of the collector and it is black and sooty in the pipes but it isn't bellowing black smoke. As I stated in another reply, I believe the carb was tampered with and sent back. There are some signs that I didn't notice until I started closer inspection when I couldn't get it to idle right.
If I wanted to send it to you to look at and setup, how would I go about getting it to you (address) and how much do you charge for this? I have a few more things I'm gonna try first though. I appreciate your reply to this post.
Old Aug 27, 2005 | 11:56 AM
commando57's Avatar
commando57
Default I have fresh copies of the Lars papers.
One is titled BG carb installation 307k
and one is titled BG carb setup 70k
I can email them if you send me an address.
To DEMONS With IDLEZE...Please Read
