Lil Guy
Old Aug 25, 2005 | 06:59 PM
Doug Farrar's Avatar
Doug Farrar
Default Lil Guy
I have a 71 and the wiper door will not open.Any ideas.
Old Aug 25, 2005 | 07:10 PM
25th silverbullet's Avatar
25th silverbullet
St. Jude Donor '05-'07
Lube?
Can you open it by hand?
Do those use vacuum? Could be a leak...
I don't have wiper doors but thought I would take a stab at it.
Old Aug 25, 2005 | 07:55 PM
Techno's Avatar
Techno
Check all vacuum lines starting with the vacuum motor on the door.
The lines are probably old and they lose thier grip. One might look like its on but isn't.
I went through this one morning and found out later just a hose was slipped off.
Then do the trouble shooting of all the gizmotron controlling stuff.
Oh and if you don't know there is a manual over ride under the dash. If this don't open it then do the checks.
Old Aug 26, 2005 | 12:56 PM
68sbShark's Avatar
68sbShark
Start with the override. If that works, then it is most likely a faulty wiper door solenoid (behind the tach in the dash), or a bad wiper switch.
Do the wipers work if the door is opened via the override switch?
Good luck
~Rich
Old Aug 29, 2005 | 05:53 PM
Doug Farrar
Good luck
~Rich
The wipers work fine if you open the door by hand.The manual overide doesnot work either
Old Aug 29, 2005 | 07:19 PM
cosmicvette's Avatar
cosmicvette
Ive got exactly the same problem.
I think I have a vacuum leak. Its well worth investing in one of those vacuum gauge tools and trying to find the source of the leak. I heard its good to start at the intake and work your way out?
My mechanic told me to get one of the vacuum gauges with the pump...he showed me how to use it...
so Im going to give it a go..once I buy this tool.
To Lil Guy
