Shocking Advice
Old Aug 25, 2005 | 09:42 PM
flynhi's Avatar
flynhi
Default Shocking Advice
I have KYBGR2s on my 71 Vert and I'm not quite satisfied with my ride quality. Tech at KYB provided the compression and rebound specs below. Can someone help me interpret what these mean in layman's terms? Any help appreciated.
343127
.1m/s .3m/s .6m/s
55/20 140/45 235/70
343128
.1m/s .3m/s .6m/s
55/20 140/45 235/70
Old Aug 25, 2005 | 09:49 PM
zwede's Avatar
zwede
The specs mean the following:
At a movement rate of 0.1 m/s (4"/second) you need a force of 55 in compression (pushing the shock together) and 20 in rebound (pulling apart). Don't know if the number is kilograms or lbs.
Old Aug 25, 2005 | 09:50 PM
Rockn-Roll's Avatar
Rockn-Roll
If the rate is in metric, then I would expect the forces to be in metric...thus 55 kg
Old Aug 25, 2005 | 10:03 PM
flynhi's Avatar
flynhi
Would these rates be considered soft, mild or stiff?
Old Aug 25, 2005 | 10:53 PM
marshrat99's Avatar
marshrat99
I've got the same shocks on mine and I'd consider the rates soft-to-mild. IMO, not as stiff as I'd like but much better than the stock shocks that I replaced.
Old Aug 25, 2005 | 11:42 PM
flynhi's Avatar
flynhi
Marshrat,
Do you have steel or composite springs? What rates front and back?
Old Aug 26, 2005 | 08:27 AM
1970 Dave's Avatar
1970 Dave
Just put on a set of Bilstein "Sports"----WOW like them alot--not overly stiff ride but noticeably firmer and better handling than the AC Delco's and stiffer than the KYB's I had. I thought long about the regular Bilsteins but talked with the VBP people and after talking with them awhile they convinced me to go with the Sports.
SEMPER FI--1970 Dave
Old Aug 26, 2005 | 02:11 PM
flynhi's Avatar
flynhi
Dave,
Any idea where I can get the specs on Bilsteins?
Old Aug 26, 2005 | 11:51 PM
Double Aught's Avatar
Double Aught
I had those on my 78 Pace with the 330 rear spring and the 550 front coils. Best combo and I ran GR2 in front with the regular KYB in back. Huge diff in handling and ride.
To Shocking Advice
