Carb advice
Old Sep 1, 2005 | 02:43 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Carb advice
I need some advice on a carb. Currently i have a 600cfm holley 4160 but I do not think it is enough to get the job done. Comp cams says to ues a big carb for my cam. here is my specs on the cam.
Part Number 12-512-5
Engine 1955-1998 Chevrolet
262ci-400ci
8cyl.
Grind Number CS280TLS-6
Description
Intake Exhaust
Valve Adjustment 0.018 0.018
Gross Valve Lift 0.53 0.55
Duration At 0.02 Tappet Lift 280 288
Valve Timing At 0.05
Open Close
Intake 19 51
Exhaust 56 23
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 250 259
Lobe Lift 0.3534 0.3667
Lobe Separation 106
Recommended Valve Springs 986-16
This is what the guys used when they built my motor it was purchased as a kit so the question is what cfm carb do I need and what is a good one to go with.
Old Sep 1, 2005 | 03:10 PM
Silver00V6Camaro
Comp cams description says SOLID-Good for 350-400 on big 3/8 to 1/2 mile tracks with high sustained RPM. Best with big carburetor and good intake.
So what is a good intake. I currently have an edelbrock Preformer. Also what would be a good tourqe converter?
Old Sep 1, 2005 | 03:48 PM
big_G's Avatar
big_G
That's a thirsty cam, give it a 750 dp and performer rpm....and a 2,300rpm stall converter, and call me in the morning!...
Old Sep 1, 2005 | 04:20 PM
lars's Avatar
lars
You can even run a Victor Junior intake with that cam and rpm range, if hood clearance is not an issue. I'd run an even higher stall - get the stall up into the 3200-3500 rpm range if you want to get it into the torque curve for launch.
Old Sep 1, 2005 | 04:22 PM
Older Than Dirt's Avatar
Older Than Dirt
Wouldn't you need like a 4000 stall and 12:1 compression for a cam like that? I don't know, I'm just asking.
Old Sep 1, 2005 | 04:31 PM
Silver00V6Camaro
I have 10.5:1 compression. The guy that built it supposedly put a 3000 stall in the car but it is a dog I can not even spin the tires if i punch from a dead stop. Also I am running the ecklers l88 style long hood. Also I am not using this as a drag car I am going to drive it about everyother day so I want the lowest stall I can get.
Old Sep 1, 2005 | 04:35 PM
Silver00V6Camaro
most of the 750dps if find are mechanical seconday. Is that a problem also so I have a new stock gm hei would that have to be replaced. I had a accel supercoil but got janked when the guy built the motor.
Old Sep 1, 2005 | 04:37 PM
CGGorman's Avatar
CGGorman
Your builder needs to put a smaller cam in. You've got the OPPOSITE of a daily-driver cam...
Old Sep 1, 2005 | 04:52 PM
Silver00V6Camaro
What about the torker 2 intake?
Old Sep 1, 2005 | 05:04 PM
lars's Avatar
lars
It's a dawg in every test I've ever seen on it...
Mechanical secondary is what you want - all DP carbs are mech sec.
If you don't want a drag car, you need to re-think your cam and comp ratio... you have a hi-rpm drag car that will not perform well below 3500 rpm.
Old Sep 1, 2005 | 05:08 PM
Silver00V6Camaro
The car is already done and this was a trade out so I am stuck with what I got. What I ment by everother day being driven is weekends and sometimes to work and school. Not a daily diver. The guy that built it said that it is supposed to be close to 400hp. Now even with it set up as is I have pulled all the way to 4500 to 5000 rpm and I am not impressed this thing does not feel or act like it has anything above the ole 165hp l48 that was in it. hell my v6 camaro fells faster. they used the heads that where with the block that they had i do not know the number on them or anything but that they came from a 69 vette or camaro. They did not use the l48 block.
Old Sep 1, 2005 | 05:09 PM
tshort's Avatar
tshort
CI 7-8 Veteran
I have an extremely similar cam in mine. Mine's a 383 w/10.8:1 compression. .543int/.561ex, total dur 288int/298ex, dur @ .050 249int/259ex and 106 centerline.
I'm still breaking in the motor but it is very healthy and can easily break loose my 275/60/15 Nitto drag radials. I'm running a Holley BG 750 double pumper and Vic Jr intake with 1 inch spacer. I haven't taken it above 4800 rpms yet and it's just barely starting to really wake up at that point.
I'm no expert but I'd say you've got some fairly big bottlenecks somewhere in your setup. Don't forget, a cam that wants to breath needs to inhale AND exhale. Don't forget about your exhaust system as well as intake and carb.
Mine is very streetable with the vic jr and you've got plenty of room under that L-88 hood. An RPM might net you a little more tq but it's going to cost you hp. Totally up to you depending on how you plan to use it.
Old Sep 1, 2005 | 05:12 PM
tshort's Avatar
tshort
CI 7-8 Veteran
I wonder if your heads are too small?? Lars?
Old Sep 1, 2005 | 05:14 PM
big_G's Avatar
big_G
Bummer about the cam selection for a street vette, but perhaps you can play with the cam timing (advance) to shift the rpm peak down a little, and stay with a dual-plane intake. On the street, I would still stay with no more than a 2,300 stall on the street. I think a 750 dp will fix your low power problems, as long as you maximize the ignition timing.
Old Sep 1, 2005 | 05:18 PM
Silver00V6Camaro
Thats what I am wondering. They told me they took them to the machine shop and had them worked but I do not know if they did. this is what the guys kid told me when he worked for us at my shop. the number on the block is 3970010. And like I posted before this motor they built was out of a 69 Vette or Camaro so what ever heads they would have had should be whats on the motor.
Old Sep 1, 2005 | 05:21 PM
Silver00V6Camaro
Yeah I traded them a all steel 34 ford tudor sedan body for the motor build of what I thought they where going to make me a street vehicle. I do not want to affend anybody but the guys that built the motor are pretty redneck and told me that a drag car was a street vehicle to them. I told them I wanted a daily driven street vehicle. I guess this was there interpertaion of a streetable car.
Old Sep 1, 2005 | 05:25 PM
not a '76's Avatar
not a '76
and thats why modified cars arent worth alot of money.
you dont know what you got.
dont know what the last guy did or why.
and dont know how to fix it except starting from "stock" again.
ive found that you gotta start with something stock and/or semi mass produced and be very scientific with your modifications.
or you end up spending a **** load of money.
best of luck making it "right"
edit: i didnt read your last post... but i think what i said still makes sense.
To Carb advice
Old Sep 1, 2005 | 05:30 PM
Silver00V6Camaro
by the way so everybody knows the car I am talking about looked like this when i got
BEFORE
AFTER
Sorry for not having updated pics The car is complete and all put together.
Old Sep 1, 2005 | 05:33 PM
Silver00V6Camaro
Also I am running true dual 2.5 in into Dynomax Superturbo mufflers.
Old Sep 1, 2005 | 07:08 PM
Older Than Dirt
If you are going to be tooling around town mostly I believe I would sh*t can that cam. It doesn't match your other engine components. You have spent alot of time and money on the rest of your car, why not install a high torque street engine. These guys here can give you suggestions on what to do. BTW, don't listen to dem rednecks anymore!
