C3 traction bars
Old Sep 4, 2005 | 12:21 PM
gleveric's Avatar
gleveric
Cruising
Default C3 traction bars
I'm looking for some info on traction bars for a 77 Vette. Who makes them? and does anyone have any good pictures of them installed? Thanks, Gary
Old Sep 4, 2005 | 12:28 PM
gator79's Avatar
gator79
traction bars are for leaf spring vehicles, not for corvettes
Old Sep 4, 2005 | 12:45 PM
gleveric's Avatar
gleveric
Cruising
http://www.vbandp.com/detail.aspx?ID=426
I found these (link above) just wondering how they worked...
Old Sep 4, 2005 | 01:53 PM
rihwoods's Avatar
rihwoods
Well,one pair of brackets must be welded to your frame...and they won't work on 78-79 vettes,from what I understand..don't know about your 77.....
Old Sep 4, 2005 | 02:43 PM
toddalin's Avatar
toddalin
These are really a rear end locating device rather than a traction bar. They just keep the rear end from wobbling around under hard acceleration. South Side Machine also makes them and they are a bolt on affair. They will not work if you have the rear crossover tube, which is right in the way of the bar.
The better way to go (lighter, cheaper, and easier to install), if the Guldstrand rear-end locating device, which will work with the exhaust crossover. I have this system on my '64.
Old Sep 4, 2005 | 02:44 PM
toddalin's Avatar
toddalin
http://www.guldstrand.com/locate.htm
Old Sep 4, 2005 | 03:07 PM
rihwoods's Avatar
rihwoods
Disc's are for 80-82 only....
http://www.guldstrand.com/vettemain.htm
Old Sep 4, 2005 | 05:16 PM
norvalwilhelm's Avatar
norvalwilhelm
Old Sep 4, 2005 | 05:26 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I think that link is incorrect. I have similar disks from VB&P on my 76. I don't see how they would work on a 80-82 rearend. I also replaced the rubber bushings with polyerthane.
I think the "traction bars" remove wheel hop on stock mounted rearends, but I don't have any personal experience with them.
Jason Staley
Originally Posted by norvalwilhelm
SWEET
Old Sep 4, 2005 | 08:33 PM
toddalin's Avatar
toddalin
You guys are reading it wrong!
Kit G02-007 is for '63-'79, Kit G02-007A is for '80-'82
Old Sep 4, 2005 | 08:35 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
You can prevent wheel hop just by going with a stiffer rear spring... 400 lbs/inch or stiffer will get rid of wheel hop...
Old Sep 4, 2005 | 11:44 PM
rihwoods's Avatar
rihwoods
OOPS..missed that other number...going blind..
Old Sep 5, 2005 | 01:28 AM
Empatho's Avatar
Empatho
is this true that they dont work on the 78
Old Sep 5, 2005 | 11:02 AM
rihwoods's Avatar
rihwoods
See note bottom of page 29 of VBP online (PDF)catalog...."Will not fit 1978-1979 rear end covers....."
Rich
Old Sep 5, 2005 | 01:37 PM
WESCH's Avatar
WESCH
Hi
Here a pic of a bar on my 68 BB.
The pic was taken to show the bent strut rôds, those are replaced by now.
The traction bar is suppost to tak acceleration torsion away from the rear end.
It is boltet to the lower end of the rear and welded to the crossover frame fwd of it.
It also sits in a angle .
Günther
Old Sep 5, 2005 | 02:25 PM
rihwoods's Avatar
rihwoods
Thanks..good picture...the offset(angle) looks to be about 3" from center...maybe 10-12 degrees..??
Old Sep 5, 2005 | 03:08 PM
Empatho's Avatar
Empatho
Rich
I asked because it says "Traction Bar 1963-79 Corvette" on their page and I was just wondering
Old Sep 6, 2005 | 12:05 AM
gleveric's Avatar
gleveric
Cruising
awsome pictures, thanks alot!! Gary
To C3 traction bars
