-73 tach problem
Old Sep 7, 2005 | 03:40 AM
Vesa's Avatar
Vesa
Default -73 tach problem
symptoms are:
Some times the tach has done so that it stays around 1500rpm and does not move at all...usually it after 5-10 miles starts waking up a bit so that if I rev the engine 3500rpm it slowly follows to 2000rpm and if I idle at 650rpm it slowly drops to 1000 and then later suddenly start working like no problem...sometimes when i shut the engine of the needle still points at 700rpm
Tried to check the cable from distributor end - nothing looked loose there, but the other end I could not reach even spending some time laying on the floor......is the cable loose from one or the other end or is the tach itself starting to fail...
But basically arent those syptoms more saying that the tach is going to break? Is it possible to rebuild the tach myself or should i just order a new from zip 270$ or ecklers 290$ ?
Old Sep 7, 2005 | 05:00 AM
Vesa's Avatar
Vesa
..and the distributor is brand new (less than 300miles in it) MSD pro billet corvette tach drive unit.
Old Sep 7, 2005 | 07:29 AM
Vesa's Avatar
Vesa
Old Sep 7, 2005 | 07:36 AM
Gordonm's Avatar
Gordonm
I would try to remove the cable first. The grease inside sometimes gets real sticky and hard. Pull the cable out and clean the cable and then put on a light grease. Slide it back in and see if that helps. I know that is not easy but it is free to try. The tach can be rebuilt with a new head or replaced if the cable is OK. Also check both ends to see tha t they are not rounded off.
Old Sep 7, 2005 | 07:47 AM
Vesa's Avatar
Vesa
Ok, thanks, that I will do tonight...
Old Sep 23, 2005 | 03:44 PM
Mike Mercury's Avatar
Mike Mercury
...The tach can be rebuilt with a new head or replaced if the cable is OK. Also check both ends to see tha t they are not rounded off.
the tach can also be converted over to electronic use... using your original dial face and pointer. A total stealth conversion.
email me for details:
tim-yvonne@juno.com
Old Sep 23, 2005 | 03:59 PM
GUSTO14's Avatar
GUSTO14
I would try to remove the cable first. The grease inside sometimes gets real sticky and hard. ....
But before you do this, and since you do have a new MSD distributor, disconnect the tach cable from the distributor and spin the cable to see if you get a reaction on the tachometer. You can use a reversable drill also to see if it moves smoothly or intermittently. If the tach responds to this as you've described above, you can easily eliminate the distributor as the problem and dive into the back of the dashboard... The cable must be removed from the tachometer end, so you're gonna have to get dirty...
Good luck... and let us know what you find
GUSTO
Old Sep 23, 2005 | 04:07 PM
Vesa's Avatar
Vesa
I have removed the tach from the car and after trying to learn how it works (and after tearing in into bits and pieces) I found that the main bearing has too much end play - so there is only small tuning possible to do which might help for a short while but anyway it is at the end of the lifecycle now...
And the cable is all ok.
So I will place a order to some shop and get a new unit...
To -73 tach problem
