Temperature gauge problems......
Old Sep 12, 2005 | 09:32 AM
Pumpkinbiker00's Avatar
Pumpkinbiker00
3rd Gear
Default Temperature gauge problems......
Hello!
I'm having a problem w/ the temp. gauge on my fathers car. The gauge works properly until the lights are turned on, then it pegs. I've searched all the temp. gauge threads w/o finding what I'm looking for. Can somebody point me in the right direction??
Thanks in advance....
Old Sep 12, 2005 | 09:53 AM
marshrat99's Avatar
marshrat99
What year is your father's ride?
Old Sep 12, 2005 | 10:05 AM
big_G's Avatar
big_G
It sounds like the black ground wire for the gauge cluster is not hooked up...look there first
Old Sep 12, 2005 | 10:19 AM
Pumpkinbiker00
3rd Gear
Sorry, I forgot to specify. It's a 79 (L82).
Old Sep 12, 2005 | 10:23 AM
TPIShark's Avatar
TPIShark
Definitely sounds like a ground issue somewhere. The increased load from having the lights on is doing it in. I had a GTA clone I built once that drove me crazy (poor idle, guages off by a mile, etc.) until I found and connected the tail that goes from the negative battery cable to the radiator support. Then whoala ! , everything was perfect.
In this case, I agree with big G - ground wire for the cluster.
Old Sep 12, 2005 | 10:26 AM
Pumpkinbiker00
3rd Gear
Thanks for the insight, everyone!!! I'll be checking for ground issues this evening.
To Temperature gauge problems......
