Better performance.......
Old Sep 20, 2005 | 02:32 PM
vette64772's Avatar
vette64772
Default Better performance.......
Hey everybody, love this site. I have a 77 with a freshly built 383 stroker/auto transmission. It cruises great, but am looking for more get up and go. It has a new Edelbrock 1407 carb, Performer RPM intake, timing is set at 10deg. initial and 34deg. total. Everything on top is new, plugs, wires etc. Was wondering what I can do to get more power at take off? It has stock distributor with 50,000 volt coil.......anything I can do to make it a light to light rocket ship?
Any suggestions would be greatly appreciated!
Old Sep 20, 2005 | 02:36 PM
pauvil's Avatar
pauvil
what kind of gear ratio in the rear???
Old Sep 20, 2005 | 02:38 PM
vette64772's Avatar
vette64772
Default No idea as to rear ratio
How would I find out what it is?
Old Sep 20, 2005 | 02:40 PM
pauvil's Avatar
pauvil
you can make a mark on the tire and driveshaft, rotate the tire one full turn and count the revolutions of the driveshaft. I saw a thread once that they were saying about a formula while cruising at 70 mph to look at the rpm and divide it by something or #@%%^$%^& whatever.
Old Sep 20, 2005 | 02:44 PM
vette64772's Avatar
vette64772
Default Tire size a factor?
Would the fact that tire size has changed from 225/70/15 to now 255/60/15 make a difference in this approach? How do i get the ratio by turning the tire/shaft?
Old Sep 20, 2005 | 02:53 PM
pauvil's Avatar
pauvil
you can put a 50 inch tire on and one rotation is still one rotation, no it won't affect you getting the ratio, but it will affect the final drive on the street, sounds weird right. If you rotate the tire once and the shaft spins 3 times, your around 3:08 if the shaft spins 3.5 times, 3:55 and so on, you only need to rotate the tire once.
Old Sep 20, 2005 | 02:55 PM
Fevre's Avatar
Fevre
also could look at your torq conv, if it is stock a higher one like 2600-3000 rpm's will get you into the powerband a lot quicker.
Old Sep 20, 2005 | 03:00 PM
JBR's Avatar
JBR
Tire size will not make any difference when trying to determine your rear ratio. Example 3.55 rear end = 1 full rotation of your tire will be 3.55 rotations of the drive shaft (imput shaft to your rear).
Old Sep 20, 2005 | 03:13 PM
WhichVette?'s Avatar
WhichVette?
Probably the gears. I've got a 3.36 rear, and it is a dog on the launch. However, I've got a strong, high winding motor that more than makes up for it after 3000rpm. Considering you've got a lower revving stroker, new gears are probably in your future.
Also, make sure you are holding your gear until you get up to just past max power for your engine. Mine will shift way too soon unless I drop the gears myself.
Old Sep 20, 2005 | 03:30 PM
redc3's Avatar
redc3
back to your original question, how to make it light like a rocket? you failed to mention what type of heads and cam your using in this fresh engine. heads and cam selection are the heart of every engine, and will determine how well/fast/strong, or bad it will perform
Old Sep 20, 2005 | 04:00 PM
flynhi's Avatar
flynhi
In additon to the above comments on gears, heads and cam, a properly curved distributor will make a huge difference.
Your current initial and total look a bit low to me.
The most effiecient way to do this is to find a shop with a distributor machine and have them recurve your distributor with proper weights, springs, bushings and vacuum advance can.
Better induction (KN) and exhaust (ceramic coated headers, 2.5" pipes, x crossover, magnaflows or Super turbos) will certainly help.
Old Sep 20, 2005 | 04:03 PM
Hauq`'s Avatar
Hauq`
Even though it has a 383 the compression is where the power is at. If you want it to rocket from light to light get a manual transmission.
Old Sep 21, 2005 | 11:52 PM
glen242's Avatar
glen242
Both tire sizes are in the 27"-27 1/2" range, therefore, interchangable.
With my 26" tires and 3.36 rear end, this works out to the equivalent of a 3.55 rear end with stock +/- 27" tires.
Old Sep 22, 2005 | 08:58 AM
Boofers's Avatar
Boofers
Fuzzy dice hanging from the rearview mirror are good for another 10hp or so.
Old Sep 22, 2005 | 09:35 AM
CGGorman's Avatar
CGGorman
Rat.
Seriously, I'd look into the timing curve and gearing.
Old Sep 22, 2005 | 12:10 PM
BKbroiler's Avatar
BKbroiler
My 77, with 383, auto etc (see sig) has run under 2 seconds 60 foot times on BFG Radial T/A tires. Gears and torque converter are critical.
Old Sep 22, 2005 | 03:21 PM
holley505's Avatar
holley505
I BELIEVE 77 ONLY HAD THE 3.36 GEAR WITH AUTO...
With an auto... YOU NEED A STALL CONVERTER !!!!!
that will increase you 60ft times... which gives you better performance light to light.
Yes the gear ratio will help also... but with an auto you will not be in the meat of your power band. The stall allows a Flash in RPM before TAKE OFF!!
That is why a stick shift is nice... you can hold the revs up to say 3000rpm and let the clutch fly(or ride it out)... if your tires stick and you dont burn to much rubber you will get a hole shot on the guy in the other lane...
The stall converter will get you more ET over all than the gears alone...the combination with an AUTOMATIC will usually leave the stick shift guy in the dust at a red light.
Your auto will be consistant performer... YOUR stick shift guy will need to be a pro to keep up with a 3.70 gear and 3000-3500 10in stall converter... YOU WILL KILL HIM!!
PS... yes tire diameter effects the gear ratio and your speedo... short tire better gear ratio (but usually less traction) taller tire hurts your gear ratio but can improve traction (better high MPG not that we care )
To Better performance.......
