MSD Igmition
Old Sep 21, 2005 | 05:32 PM
vette64772's Avatar
vette64772
Default MSD Igmition
I am running a fresh 383 with Edlebrock 750 carb, performer rpm intake headers 2.5" exhaust, Comp Cams 280H.......etc. Stock distributor. Should I consider running an MSD 6a or 6al or what? What would the benefit be, if any, and what are any drawbacks? Might consider a shot of N2O in the future just for fun..........opinions on the MSD?
Old Sep 21, 2005 | 05:36 PM
Fevre's Avatar
Fevre
Crane makes a nice digital unit that is cheaper and comes with a built in dial rev limiter, I have one in my Formula.
http://store.summitracing.com/partde...=KeywordSearch
Old Sep 21, 2005 | 05:42 PM
vette64772's Avatar
vette64772
Says the Crane unit is for up to 9:1 compression engines...........mine is 10:1. Make a difference?
Old Sep 21, 2005 | 05:51 PM
JoeRags's Avatar
JoeRags
I have a 6AL, Pro-Billet dist, and a Blaster HVC coil on my 383. It runs like a bear, starts right up, and loves when I lay into the throttle. If your thinking of N20 in the future, MDS makes special units especially for use with the funny stuff. I know for sure the Digital SCI+ has a retard stage to prevent detonation when you hit the button.
Old Sep 21, 2005 | 06:15 PM
Fevre's Avatar
Fevre
Actually 9.5/1 but what's .5 a point? Mine 350 is 9.75 running with no problems.
BTW I have a 6A and MSD Dist in my vette and I have had no problems with it.
Old Sep 21, 2005 | 06:22 PM
Gordonm's Avatar
Gordonm
WOW! They have gone up in price. My HI6 was about 150 bucks a few years ago. It is for engines up to 12 to 1 and has a built in rev limiter. They now make one for 10.1 to 14.1 motors and turbos superchargers and Nitrous. Little more expensive but they work great. MIne is fired by the stock dist using a set of heavy duty points to trigger it. Works very well to 7000+ rpm.
Old Sep 21, 2005 | 06:32 PM
vette64772's Avatar
vette64772
Work with my HEI distributor right?
Old Sep 21, 2005 | 06:47 PM
Nate '69's Avatar
Nate '69
I'm using an MSD. If you get one at least get the 6AL not just the 6A
Old Sep 21, 2005 | 06:53 PM
Gordonm's Avatar
Gordonm
Yes it will work with the HEI
Old Sep 21, 2005 | 07:54 PM
69vettester's Avatar
69vettester
I replaced an old mallory dual point with a MSD Probillet dist. 6A Box and 8.5mm superconductor wires in My 69 sb.
I was able to set it all up in a few hours, It fired right up ,the engine has run very strong and efficient for the last four years
The Engine has never stuttered once while running.
Excellent ignition.
Old Sep 22, 2005 | 11:28 AM
redc3's Avatar
redc3
im using the new msd pro billet e- curve distributor. it has no springs or weights, and i can set my advance curves with a screwdriver, on the printed circuit board inside. it also has a built in rev limiter, and can be used with or without the 6al box. its one of the nicest units ive ever worked with. havent heard others here mention it yet.
To MSD Igmition
