steeroids binding on a-arm
Old Sep 25, 2005 | 05:33 PM
fcoppola's Avatar
fcoppola
Default steeroids binding on a-arm
Has anyone experienced this? There is little to no clearance where the ujoint and a-arm touch. I even used the 'smaller' screws included, but they still hit against the a-arm. If I cut the screw to be flush with the ujoint I think it will be fine. Since its a hex I dont think I need to put the bolt on it as long as its tight. Any ideas?
Old Sep 25, 2005 | 05:52 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
grind the a-arm a bit. always use a lock nut with the set screw, and use red lock-tite on both.
Old Sep 25, 2005 | 06:01 PM
fcoppola's Avatar
fcoppola
Default ok
thats what I was thinking ... Will a dremel do the job?
Old Sep 25, 2005 | 06:37 PM
mrvette's Avatar
mrvette
If you have the suspension up in the air/unloaded, and then loaded and you see ANY possiblility of anything hitting/binding....
buddy you got problems far as I'm concerned....when under dynamic cornering loading, one way or another, I feel you need about 1/2 inch of clearance, just on account of the rubber and steel flexing in what for US is an unknown direction....
I don't feel grinding anything willl get you 1/2 inch...
other solutions?? I dunno, not without seeing the car...sorry...
GENE
Old Sep 25, 2005 | 06:59 PM
Twin_Turbo's Avatar
Twin_Turbo
Old Sep 25, 2005 | 08:22 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you are saying a-arm???? do you mean the frame cross member? can you move the lower brackets back at all where they bolt into the old steering gear holes, can you move the heim joint back at all closer to the passenger compartment or can you move the ujoint back more on the steering column? my hex heads and lock nuts were close but they did not hit anything and yes i would use that lock nut on those, almost sounds like to me your set up is to far forward.
Old Sep 25, 2005 | 09:49 PM
84rzv500r's Avatar
84rzv500r
I had the same problem... No way the bolt heads were gonna clear the A-Arms.
I ended up taking some flange head bolts and turning them in the lathe so that the were sort of low profile. The load is all shear any way. Why would you grind on the A Arms ? It dosent make them stronger...
Check the Archives...
Old Sep 26, 2005 | 07:11 AM
fcoppola's Avatar
fcoppola
the part where the single ujoint connects to the rack and pinion unit. It is connected with 2 hex screws. The hex screws rub on the a-arm. If the hex screws were flush and not sticking out I would have no binding at all.
Instead of grinding the a-arm I was thinking of shaving the flange bolts to be flush with a good amount of locktite.
Old Sep 26, 2005 | 07:39 AM
mrvette's Avatar
mrvette
FOR all the world man, it sounds like you are mis naming something there, the A arm is the lower suspension unit, with the two mounting points on the engine cradle to the inside, and the ball joint, then there is a upper A Arm.......what you allmost have to be refirring to is the engine mount part of the frame, what I call a horn...
GENE
Old Sep 26, 2005 | 08:51 AM
Fevre's Avatar
Fevre
In the kit they provide shorter hex screws that do not allow use of the nuts so you need to use some loc-tite to keep em in. Re-read the directions and I believe it refers to the use of the shorter hex (set) screws.
There are 2 short set (hex) screws listed in the parts list and are referred to in Item 16 in the instructions.
Old Sep 26, 2005 | 02:28 PM
davidm_comp's Avatar
davidm_comp
Just to make sure we are all talking about the same thing here, is it the lowest set screw, connecting the u-joint to R&P unit, cause that is pretty close for me too.
Old Sep 26, 2005 | 04:04 PM
waterplay's Avatar
waterplay
YES it must be that! I had the same prob. Now to set things straight it is NOT the A-Arm!!! What it is hitting is what was already refried to as the… Horn.
“FOR all the world man, it sounds like you are mis naming something there, the A arm is the lower suspension unit, with the two mounting points on the engine cradle to the inside, and the ball joint, then there is a upper A Arm.......what you allmost have to be refirring to is the engine mount part of the frame, what I call a horn...”
GENE
Now what I did is remove as little metal off of the horn as needed to clear the swing of the joint retaining stud and lock nut. Very easy if you have a grinder. You will loose no structural integrity and the horn is stationary so no need to remove a lot of extra. I hope this clears it up for all.
Old Sep 26, 2005 | 04:38 PM
Twin_Turbo's Avatar
Twin_Turbo
what is the horn???
Old Sep 26, 2005 | 05:06 PM
fcoppola's Avatar
fcoppola
exactly... the shorter ones are still hitting. This is my problem.
Old Sep 26, 2005 | 05:07 PM
fcoppola's Avatar
fcoppola
exactly. That is what I am talking about.
Old Sep 26, 2005 | 05:11 PM
fcoppola's Avatar
fcoppola
Ok that clears things up. I thought that was an a-arm. My apologies for the confusion. I've never heard of this being called a horn?
Old Sep 26, 2005 | 05:15 PM
mrvette's Avatar
mrvette
Originally Posted by Twin_Turbo
what is the horn???
TT, I have called it the horn for a long time now, they are the engine mounts that mostly stick out from the frame to accept the engine mount bolts....running fore and aft...
been calling them that for decades now....any car....
I think horn on a cow/stear, not to be confused with bumping stears....
allthough in this case just part of a stear is being bumped??
GENE
To steeroids binding on a-arm
Old Sep 26, 2005 | 05:17 PM
Twin_Turbo's Avatar
Twin_Turbo
it's a motor mount..okay (as far as I know, the horns are the 2 extensions on the front of the frame, to which the front frame extension bolts)
You could grind a little clearance on the engine mount but in all reality..crummy aftermarket junk is what causes this. (flame suit on)
Old Sep 26, 2005 | 05:34 PM
mrvette's Avatar
mrvette
hehe....see previous post...
anyway, I had to cut back the rear lower section of that horn in my install, but I cut much more of it, on account of my rack is higher and more angled up toward the steering wheel, and so need only two universal joints....
GENE
Old Sep 26, 2005 | 05:49 PM
Fevre's Avatar
Fevre
Still have a slight bind in mine, will have to climb under and have a look see, thanks for heads up.
