Unwelding Mufflers
Old Oct 11, 2005 | 04:44 PM
dennis's Avatar
dennis
Default Unwelding Mufflers
I need to replace a muffler. (have a replacement).The pipes in great shape and I want to reuse it until I replace the whole system. The muffler is welded to the pipe. Any suggestions on accomplishing this?
Old Oct 11, 2005 | 04:45 PM
Twin_Turbo's Avatar
Twin_Turbo
cutting disc, oxy acet, plasma cutter, sawzall...what do you have that could do the job?
Old Oct 11, 2005 | 04:46 PM
Fevre's Avatar
Fevre
Old Oct 11, 2005 | 05:06 PM
lars's Avatar
lars
Using a high speed cutoff wheel on a high speed air grinder you can do a neat surgical job of removing the weld and cleanly separating the muffler.
Old Oct 11, 2005 | 06:15 PM
dennis's Avatar
dennis
Thanks ,going to try the cutoff wheel.
Old Oct 11, 2005 | 06:39 PM
comp's Avatar
comp
there is a cutter that works like like a tubing cutter
Old Oct 11, 2005 | 06:45 PM
dath's Avatar
dath
I like the chain cutters myself for that kind of job. They will make a perfect cut. The only problem is that they are slow and annoying to use compared to a cutoff wheel. I wouldn't get near it with a Sawsall unless you want to make a mess out of it, but maybe that's just me. I can't cut anything near a straight line with one.
-dath
Old Oct 11, 2005 | 08:06 PM
dennis's Avatar
dennis
I thought about a plumber pipe type cutter. I don't care about cutting the old muffler inlet pipe, but I have to preserve the long pipe that slips into the muffler inlet pipe about 2 inches or so. If the cut wheel doesn't do it, I'll try the pipe cutter
Old Oct 12, 2005 | 02:57 PM
comp's Avatar
comp
To Unwelding Mufflers
