Fuel Line Return Question/Configuration
Old Oct 23, 2005 | 08:44 PM
sarchevyman's Avatar
sarchevyman
Originally Posted by seaboltm
i saw no "uncomplimentary" remarks above; Lars made a challenge to breathial as to information, and there was a response.
breathial's response was met by being called a "flaming azzhole".
come on.
Lars wants to lay down a gauntlet, let Lars defend it. Lars is NOT god.
i have a doctorate in physics, so anyone who wants to lay down a serious thermodynamics argument, feel free. i am listening, both Lars and breathial.
and aussiejohn, just because you drank beer with Lars in Colorado doesnt mean a DAMN thing. Lars can still be wrong, breathial can still be right, and Lars DID lay down a challenge. let Lars defend it.
Since you have a background in this area, would you mind giving us your view? I have no idea which direction or what argument to follow. I welcome all points of view, Lars, breathial, and of course yours. I see no reason why this has to be a flaming contest, I love to read up on subjects such as these and learning all I can from you guys that have studied and know your stuff. This I thank you for, and thank everyone else that helps us less educated guys learn information that without this site and the postings would not be possible. THANK YOU
Old Oct 23, 2005 | 08:49 PM
nastee383's Avatar
nastee383
DAYUM!! I didn't expect this when I opened this thread.
Old Oct 24, 2005 | 01:54 PM
lars's Avatar
lars
Some of the statements and assumptions made by Eric are factually incorrect, and they do not constitute a thermal analysis. Although non-return systems can be perfectly functional, there are better ways to design fuel systems.
I was teaching fuel/induction systems at GM when fuel return systems were being introduced and installed by the factory. We received a lot of questions about the usefulness of the return systems on the new cars by the students in the classes, and many questioned the need for the systems, as well as the practical usefulness of the return line – comments very similar to Eric’s. We found that there was resistance to the new “complexity” of the fuel systems, when a single supply line had been in use, successfully, for the past 50+ years. There were several reasons for the return line systems, and these reasons still apply:
1. Fuel supplied to the carb is kept cooler using a fuel return system. As opposed to the statement made that under car temperatures are very high, the fact is that under car temps in the area of the frame rails (where the lines are routed) are actually 50 to 100 degrees below the temperature in the engine compartment (between the radiator and the cylinder head). GM found that by circulating the fuel through the frame-mounted fuel lines, and reducing heat soak into the slow-moving fuel in the fuel line in the “hot” areas (near exhaust components and forward of the firewall), that vaporization of fuel in the line between the pump and the tank was almost eliminated, and fuel inlet temperature to the carb was significantly reduced. Enough so that customer warranty complaints about vapor lock type drivability problems were cut by over half following the introduction of return line systems in 1971 (some high performance vehicles – such as the Corvette and GTO – received return systems prior to ’71 in order to reduce the same problems). Return line systems do not prevent fuel boil-off problems after hot engine shutdown, but they are effective in reducing drivability issues related to fuel vaporization while driving. GM, and the aftermarket, has used reflective heat shields and insulating gaskets under the carb to reduce hot shutdown vaporization problems.
2. The closer the return line is located to the carb, the more effective the system becomes in reducing vapor-related problems. GM installed the return line at the outlet of the in-line filter on the Vette & GTO (very close to the carb) for this reason. On vehicle systems not using an in-line filter, there was not a practical or economical way to install a return line close to the carb (Q-Jet), so the return was designed into the fuel pump. Although a compromise, it was still highly effective in reducing fuel temperatures (and warranty claim problems). In over-the-bowl return systems in racing applications, we have measured noticeable reductions in fuel inlet temp and bowl temp from the circulating fuel – this type of system has become the standard in racing fuel systems (it's not "my" system - it's used on virtually every racecar on the circuit) for this reason. Contrary to the comment made, the system does, in fact, provide cooler fuel to the carb, and it lowers bowl temperatures, providing the carb is protected from excessive radiant and convection heating. We have actually measured it using an IR gun to validate the system. Modern factory fuel systems now do exactly the same thing: Fuel is flowed to the injectors and circulated through the fuel rail and returned to the tank through a return-style regulator system, keeping cool fuel circulating over the tops of the injectors at all times. It would be much easier – and cheaper – to regulate pump pressure at the tank and eliminate the return line, but that is not done: The return system is effective in reducing vapor-related problems, even with a tank-mounted pump, so this system is used on all new cars today. Simply maintaining line pressure (controlling saturation pressure) does not solve the problem.
3. The Vega was the only GM car at the time using an electric fuel pump mounted at the tank. It, too, used a return line. The reason for the return line was due to the design of electric pump: Electric pumps are vane-type positive displacement pumps. When this type of pump is dead-headed, the amp draw increases dramatically. The increased amperage increases the temperature of the pump, which puts heat into the fuel. It further reduces the life of the pump itself due to this excessive load and the associated heat. By using a bypass, returning fuel to the tank, the electric pump sees lower power draw, longer life, and vapor related problems are reduced due to lower temperature of the fuel since the pump itself runs cooler. Alternator life is also extended since its output requirement is lowered by reducing fuel pump amp draw. Every new car you buy today uses a fuel return line for this reason: You don’t want to dead-head an electric pump if you’re providing warranty on a new car. Performance enthusiasts can take advantage of this type of design for the same reasons.
A single-line system with no return can be made to work just fine. Every manufacturer from 1900 to 1970 used a single line system with only modest problems. In the quest for improvement, every vehicle on the road now uses a return system for the reasons noted, and many of us design and install return systems into the custom and modified cars we build to gain the added advantage of reliability and trouble-free operation. In a competitive environment where every advantage (and tenth of a second) counts, we use the best parts and the best designs – not stuff that’s 100 years old.
…and who ever said I was “selling” fuel systems..? My livelihood has nothing to do with Vettes or cars. Do you just make this stuff up..? And I’ve sure as heck never proclaimed to be “God” (comment not made by Eric). I provide solid tech advice about things that I have some knowledge about (as opposed to some others) based on 40 years of car building experience to people who request assistance. I have no other motivation, and I sure don’t make any money off the time I pour into this hobby. I have opinions about what works and about what doesn’t, and those opinions are based on factual observations and experience gained from building custom cars and racecars since the early ‘70s. I give away that information for free to those who request it. If you really think return systems are complete BS, you should contact the automakers: You could save them millions by getting them to eliminate those costly ineffective BS systems, use some wood parts, and they would surely reward you handsomely.
Gotta go now – I have a return-line system to build for a racecar. I’ll post up some photos and technical info as soon as I'm done for those interested in building nice fuel systems.
Old Oct 24, 2005 | 07:34 PM
cannonfl's Avatar
cannonfl
I'd say that man knows his stuff!
Old Oct 25, 2005 | 07:45 AM
breathial's Avatar
breathial
I never said I was giving a "thermal analysis," I said I would explain the thermodynamics (and did so, in laymans' terms). WRONG foot to start on, Lars...
As to being "factually inaccurate," it would be really enlightening to see you substantiate your claim. It is YOU, who seem to have a problem with facts... As I will demonstrate.
I don't argue about the complexity. Hell, I have to BUILD a fuel system for my EFI system that's going on to my supercharged 427. Complexity is not the issue, usefulness IS. I said before, that it's stupid to waste money on a system that can't pass the sniff test- and I stand by it. Your own words will demonstrate WHY... (as they did, in our LAST discussion...)
So, let's go down your list... one by one, shall we...?
Unfortunately, this is one HELL of a blanket statement... so vague as to be useless. What speed was the car moving? what was ambient air temperature, and under-hood temperature? What ENGINE? Was this a Corvette (with a tiny engine compartment) is was it a Vista Cruiser??? Was the car sitting with the hood up??? I mean, what you're saying is meaningless....
I ASK these questions, because (as I noted before) vapor-lock only occurs at low-speed, high-temperature conditions. With little or no air-flow under the car, heat soak WILL occur... and become even more pronounced as Tamb and Teng increase. Depending on the car, the engine, cooling system, engine compartment configuration... any one of a dozen variables can effect that magnitude (and even the significance) of such tests.... Citing such a number, given nothing else, is either insulting or amusing (depending on how one looks at it).
WOW... Now THERE is a suprise...
Originally Posted by breathial
Wanna' avoid heat soak? A simple method: use an electric pump as close to the tank as possible (dump the cam-driven one), run the fuel line(s) as far away from the exhaust and engine as possible.... Even insulate them with asbestos (or whatever) insulation to minimize heat-soak, you pretty much solve the problem with boiling in the lines....
While you don't agree with me, at least a bunch of nobodys like the the guys that are still working at GM do...
So, let's see... the biggest car-company in the WORLD... and the collective aftermarket manufacturers agree with my observations (based upon common-sense)... And the only one who does NOT, is YOU...???
Fuel temperatures where??? We come back to the same problem... Heat soak occurs at low speeds, low air-flows through the engine-compartment and under the car, and high ambient temperatures.... Note, as well... that at low-speed, low engine-load conditions, the fuel flow into and through the carb will be tiny.... hence, the cooling effect from the cooler fuel entering into the carb (while the rest is returned to the tank) will be inconsequential...
Jeez... don't you GET IT???
I've neither time, equipment nor inclination, to go out of my way and prove to you, what common-sense and logic (and, as you stated, even General Motors AND the aftermarket car-parts industry) already know...
So we're comparing our "real-world" cars to race cars, and calling them the same...? The issue is about vapor-lock at idle and low-speed, and hot-start problems... Trying to support your claims by comparing completely different cars (in every way that matters) doesn't really help you...
Several flaws in this paragraph, but the last is... well, it's just plain WRONG. Fuel-injection systems, for maximum engine efficiency and minimizing emissions, must have a consistent fuel-rail pressure... While it may be cheaper, it is not, in fact, easier to regulate the fuel pressure at the tank... not if you intend to keep your fuel-rail pressure consistent... If you've taught the classes as you claim, then you already know this...
WRONG. If the only goal is to eliminate vapor-lock, a EFI system WOULD eliminate the problem. EFI systems run at 40+ PSI, which would put the fuel rail pressure higher than saturation pressure.
The addition of the pressure regulator downstream of the fuel rails accomplishes two things, simultaneously: it assures a consistent fuel-injector inlet pressure, and eliminates the possibility of vapor-lock. Yes, it also allows cooler fuel to the injectors, but that is simply a happy byproduct of design requirements (mainly having consistent pressure at the injectors).
Agreed. Up to THIS point:
Again, you were doing so well, until the last sentence... It seems to be a trend...
All new cars use a fuel return, because all new cars use electric fuel pumps!!! Your logic- that you must not dead-head an electric fuel pump, was exactly correct... But you neglected to mention that all new cars are fuel-injected...! The LAST car I saw running a carburator (as a new model) was a 1996 Dacia... in ROMANIA!!!
When I was in Russia this past July, I noticed that even the new Llada (the Russian state-owned car company) models all have EFI...
Yeah, EFI!!!
...In a competitive environment where every advantage (and tenth of a second) counts, we use the best parts and the best designs – not stuff that’s 100 years old.
So now you're back to race cars, eh???
I provide solid tech advice .......
Clearly, your arguments and rationalizations make me wonder what you consider "solid tech advice...?"
Old Dec 2, 2005 | 09:00 PM
1971corvette's Avatar
1971corvette
My question is what is "Tamb and Teng"
Old Dec 2, 2005 | 10:17 PM
Matt 1980 L-82's Avatar
Matt 1980 L-82
my guess would be ambient temperature and engine temperature
Old Dec 2, 2005 | 10:41 PM
Lohkay's Avatar
Lohkay
You know what, I don't know enough to tell who's telling the truth BUT just by the tone and way of writing, I'd say Lars is probably right. I'm a computer guy and I know forums and you know what, breathial sounds like a
Go take a hike.
Old Dec 2, 2005 | 11:24 PM
76custompaint's Avatar
76custompaint
Return or non-return is turning into the new O-Ring vs. Lip seal debate That said I'm casting my vote with Lars and return style I like my new electric fuel pumps, and I really don't want to see them burn out. I really don't see why a person couldn't use return style and insulate their lines and put in a heat shield for their carb to really get cool fuel I do not understand why you (Brethial) say at one point that if you want to avoid heat soak to put an electric pump as close to the tank as possible, and later concede that Lars is right when he says that pump life and alternator life are reduced significantly when using an electric pump and a dead head type regulator? Believe it or not, when you say that all cars now use return style regulators only because they are fuel injected and use electric pumps, carburated cars can and do have electric pumps too, so in turn are you actually arguing that Lars is right and everyone with an electric pump should use a return style regulator? And did you not say that to avoid heat soak a person should install an electric pump? So anyone that wants to avoid heat soak should install a return style regulator? Just need you to clarify that point for me
Old Dec 2, 2005 | 11:33 PM
PRNDL's Avatar
PRNDL
pls send me a pm if brethial should post something worth reading. I have added him to my ignore list, so I won't see it otherwise. (Gawd that's a great feature!)
Old Dec 3, 2005 | 03:07 PM
MartyW's Avatar
MartyW
LOL, this was a very informative and interesting thread. I personally like debate between informative people on forums as long as it can be kept civil. I just got my 76 vette and it was built by a company called Speed innovations in Denver and it was built with no return fuel line. I have been wondering about this ever since I got the car. The return fuel line was just plugged at the very end. There was a new Hi-VOL fuel pump installed at the time it was built. The only problem that I have noticed with it was that they did not plug the end of the return line very well and it came loose while I was driving it and was pouring fuel out as I was driving and was REAL close to the exhaust headers. I was lucky the car had just been started and it had not heated up yet or I would probably have been sitting in a very large gas fire. I enjoyed the thread and learned way more than I every wanted to about return fuel lines......but I still do not know if I should get one installed. I seem to lean towards Lars thinking, but it is obvious that Breathial does have some experience with this or it would not have gotten into as heated of a debate.
Just wanted to say - Peace to all - And I enjoyed the thread and hopefully after I read it the 4th or 5th time I might understand some more on the topic and can hopefully make my decision.
Old Dec 3, 2005 | 05:31 PM
69ttop502's Avatar
69ttop502
Brethial, I sure do wish you would go away. If if you were right I would do the opposite just because your delivery has alot of nastiness toward a guy who has helped an awful lot of people. This is not the first post where you have taken a nasty tone. I am all for these type of technical posts to learn, but having to get past the personality you inject into discussions is tiring to say the least. Go away.
Old Dec 3, 2005 | 11:21 PM
  #33
Milehigh66's Avatar
Milehigh66
Default go away
brethial, I know you think you are right, and yet you are not. Lars is my friend and I will defend him for that reason alone, but he and I have disagreements about how things work as well, he is usually right, but I have had my moments. http://www.sladurana.com/free_dating/2633.html
I am sorry you can't find a date! 4 of those hits our mine out of curiosity! Sorry am married and have kids and don't want to date you!
http://hometown.aol.com/__121b_HMsUr...CMjmchz30EMw==
I know it must be tough to have to advertise yourself to get some interest in you, I feel bad that you have to do so much to get a date.
The IR readings are off of my car, with the return line and running the pump for just a few seconds cooled off my carb by 30 degrees thus making it start after heat soak with no problems. Lars helps people, he goes to different towns to tune cars out of the goodness of his heart, he makes no money on these trips. Have you helped anyone, have you even built your first engine? You say you have all the parts but have you put anything together? I have experience, I have built 11 engines so far, not all where perfect but they all ran great! Have I learned even more from Lars, yes! Dog him all you want, but he has experience which you don't, so shut the F up! When you have experience such as Johnz and SWCduke then talk all you want, but you have nothing to give this forum as I see it.
Build something, anything and maybe someone will respect you, otherwise you are a lonely man that thinks he is smart and obviously thinks he is attractive and intelligent, however the hits on your sight prove otherwise. Have a nice night brethial!
Old Dec 4, 2005 | 12:04 AM
  #34
cannonfl's Avatar
cannonfl
Milehigh66, I hope I never **** you off!
Old Dec 4, 2005 | 12:09 AM
  #35
Milehigh66's Avatar
Milehigh66
It take's a lot, but I have been silent on this one for a while! There are people that help people and then there are the know it all's that do nothing for anyone. I think we know who falls into what catagory!
Old Dec 4, 2005 | 12:21 AM
  #36
big_G's Avatar
big_G
Man, that's gonna leave a mark....
Old Dec 4, 2005 | 12:50 AM
  #37
cannonfl's Avatar
cannonfl
Agreed...
I've been reading this forum for a year or two and have seen nothing but helpful post from Lars. I've even found his articles on the CorvetteFAQ site.
Nothing wrong with debate, but breathial ... You just got plain rude.
Drama...
Old Dec 4, 2005 | 12:51 AM
  #38
Older Than Dirt's Avatar
Older Than Dirt
Hmmm.....he lives in California, maybe he could get a date with Nancy Pelosi. They both seem to have the same personalitys and attitudes.
Old Dec 4, 2005 | 01:24 AM
  #39
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Default The smallest dog makes the most annoying yap!
